Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My machine will fill with water and cycle until it is time to drain, at which times it seems stuck and does not drain. Any ideas on what my problem might be?
    Champion:
  • 245 Answers
Check your lid switch on the right side when you open the door. Try sticking a pencil in there. There should be a clicking noise. If not it is broke.
Posted on Aug 22, 2010
1 minute fill cycle,harvest cycle 3.5minutes water still filling the reservoir and down to a pan drain by the time reach the freeze cycle water seem to be in normal flow but the damage its been done before...
look for a stuck or otherwise malfunctioning water fill valve. one way to check, turn the machine off and see if the water is still running to fill it. start with that and let me know.
May 03, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Washer Is Dribbling Water Into Tub
you have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine stuck in fill cycle
It certainly sounds like the water level switch acting up. Do a couple of other checks first. Make sure you are not siphoning on the initial fill. Check your drain hose and make sure there is an air gap to the drain pipe. If you don't have a gap sometimes it will fill and siphon right out. Next would be to examine the level switch hose that runs to the tub. You want to make sure that there is no pin hole leaks in it causing this problem. Once you are satisfied the drain and tubing is ok, get another piece of tubing the same size and blow into the level switch when the machine is acting up. If the water stops, you can be almost certain it is the switch. Part number...3366847. It's important to do these checks because I have seen timers on this model mimic the water level switch. Catriver..post back.
Oct 16, 2006 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
