Question about HP Computers & Internet
On hp desktop on disk test get b10hd-2 error code
    Guru:
  • 1,082 Answers
That HP code is generally a failed or failing disk. They ask that you contact HP support. Here is the URL
http://tinyurl.com/2by9spq
You can use other disk tools to determine if it is a failed disk, then replace it yourself or have a local tech. do it.
Posted on Aug 22, 2010
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
What does a biohd-2 message mean?
That error code means that your hard disk has failed. You can use the hard disk diagnostic test in BIOS for further confirmation. If either short or long test does not pass or causes your PC to reboot, the hard disk must be replaced
Unfortunately the normal solution for this is:
Locate your Recovery disc set or usb recovery media. I hope you took the time to make it.( your HP software asked you to do this)
Purchase a new SATA2 hard disk of equal (500 GB) or greater size. Remove the failed disk and install the new one.
Follow the instructions here and restore your original operating system to the new hard disk.
May 25, 2014 | Computers & Internet
Error code B10HD-8
Is this error code uppear at boot screen?
Aug 18, 2013 | HP Pavilion Computers & Internet
Error code 0300 on disk drive A
0300 Flexible disk drive (A) boot error POST has detected the flexible disk drive (A) reported an error during its self-test.
To correct this:
1. Verify a diskette can be properly inserted and removed from the flexible disk drive.
2. Verify the flexible drive type configured in the Setup utility matches the flexible disk drive installed in the HP Server.
3. Verify all data cables and power cables are firmly connected.
4. If the problem persists, your flexible disk drive may need to be replaced. Contact your service representative.
Jul 12, 2012 | HP Vectra VL800 PC Desktop
Computer does not see hard drive. ran diagnostic test Testing booth path Error code biohd-2 no drive detected
reset the bios then check the power connector and the IDE or SATA cable for loose contact or change them see whether the hard disk is spinning or making any noise if you hear noise the hard dis is need ed to be changed if the hard disk is not spinning check the power connector and also check whether the circuit board below the hard disk is getting hot if its getting hot you need to change the circuit board of the hard disk with same company and number
Apr 25, 2011 | HP TouchSmart IQ506 PC Desktop
I have an HP Pavilion dv6-1230us notebook. I noticed some skipping on my programs so decided to restart my computer. Upon restarting it I ended up with a startup failure screen, so I had it launch startup...
Get a new drive in a caddy and boot your computer within safe mode (press F8 as it loads).
Copy all you can to the new drive.
If you cannot do that, buy a replacement hard drive and load your system disk in the CD Rom drive booting from it. When the system is loaded and running, power the desktop down, fit the old drive and set the jumper as SLAVE.
Boot up your desktop and there will be what is left of your data on drive D. Copy all you require before it is too late!
Hope that helps.
Dec 09, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
My computer is not booting, I've researched and
you may want to start asking about the motherboard if the socket is bad on the motherboard then the hard drive will not be able to read. ask a tech to take your hard drive and hook it up in another pc and see if it works if it does then you might need to replace the mother board
May 12, 2010 | Computers & Internet
I have bought a set of recovery disk from restoredisk.com for a1220n disktop.After install of disk system crashes with error:error loading kernel. Also system32hal.dll
Presumably, you bought _exactly_ the correct set of Recovery Disks for your specific HP.
Sounds like "hardware" problems:
* loose cable between motherboard and disk-drive,
* bad RAM (download and run the free 'MEMTEST86+' software to "test" your RAM),
* bad disk-drive,
* leaking capacitors on your motherboard
(do a visual inspection, looking for brown "gunk" on top of a capacitor, and looking for bulging capacitors)
* overheating motherboard
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
My computer is not booting, I've researched and troublehooted but nothing. It will not boot at all. I've done so many things. I did get a error code B10HD-2. I replaced the Hard Drive and still the same....
sorry for my language
if Your bios not recogn your hdd -that means yoyr hdd is broken - or u must change settings in your bios (older bios) - try change boot settings in Your computer.
Mar 20, 2010 | Computers & Internet
Computers & Internet Logo
375 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
