Question about Panasonic Televison & Video
My panasonic DVD-CV51 disc player won't eject or play a disc. There is only one disc in. The player just continuously opens and closes the drawer and cycles thru the each disc location. Have left off for hours, unplugged for hours and tried the default reset. No luck. About to try the BFH fix(Big ... Hammer)
  • 10,594 Answers
Before to apply BFH method as it is final and ultimate fix for these things, unplug unit from wall socket, take off top cover of DVD-CV51and clean optical lens with good quality cotton swab gently and check DVD-CV51 as dirty/ clogged optical lens does not read one disc and player go for next disc to read it and gives up after trying all discs.
Hope this info will solve your dvd player problem.
Thanks.
Posted on Aug 22, 2010
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
I accidentally loaded one DVD disc on top of another one in my DVD player. The drawer closed but will not re-open. How can I get it to open?
See if you can wedge a firm plastic tool with an edge in the crevasse of the loading tray, now as you hit eject pull down with the tool to see if you can release the mechanism but go easy. The only other option is to take the entire unit apart to get at the discs.
Dec 31, 2010 | Samsung Televison & Video
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Rumbling drive
The dvd motor needs to be service or change take it to a tech to look at it.
Apr 03, 2007 | Panasonic DVD-CV51 Multi-disc DVD Player
Televison & Video Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
