Question about Kodak EASYSHARE Z1285 Digital Camera
Camera turns on but doesn't stay on. Len is fully extended can not retrack -camera does not stay on long enough. It was dropped
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 23, 2010
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
I have the Sanyo x1250 and it dropped with the len extended. When I turn it on, the lens goes partcially in and out while making a clicking noise, and after a few seconds of this, it says system error on...
Lens errors (system errors on Sanyo's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 17, 2011 | Sanyo VPC-X1250 Digital Camera
When I turn on the camera the lens comes out and then retracks and it says to turn the power off and on again. when I turn the camera off it says the same thing
Hi, I have to say that's a problem I've seen fairly often with the Sony W320. My suggestion is to take out the battery and make sure it's fully charged then put it back in. If that doesn't work I'd contact Sony.
May 12, 2011 | Sony CyberShot DSCW320 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
The camera was dropped and the lens is extended and will not retrack. There is no control with the power switch
Try sending the camera to Panasonic Repair Center for immediate repair. They can help you repair the unit since it was hit badly during the fall.
Thank you.
Aug 01, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lens will not fully close.Len get stuck when retracking.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon Cameras
Lens wont retrack/ camera wont turn on...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Len won't close , camera won't work
Apr 17, 2009 | Cameras
Kodak EASYSHARE Z1285 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
