FOLLOWED INSTRUCTION WORKED ONCE DID TH SAME THING SO FOLLOWED INSTRUCTIONS AGAIN NOW THE WASHER SOUNDS LIKE ITS DOIN A WASH BUT THERE IS NO MOVEMENT AND THE START BUTTON IS FLASHING. WASHER DID FILL UP MORE THAN USUAL BUT THEN DRAIN.
Turn power button off (not at wall) Select 90 degree wash Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash. Leave power on. Select any Spin position. Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds. Machine should be re-set ready for use. Good luck! All we need now is for the rain to stop
Was this solution helpful? Show your Appreciation by rating it:
