Question about Hitachi Performa CP-RS55 Multimedia Projector
Have a hitachi projector CP-RS55. it has suddenly developed the following fault. on switch on both the lamp and temp warning light are flashing. i made the assumption that the machine required a new bulb, which i replaced as well as a new filter and followed the necessary procedures following the replacing of both items ie. resetting lamp time and filter time. switching on again the two lights are still flashing. can you please advise.
  • bcressell May 04, 2008
    thanks for this. fan working okay as problem started with previous lamp (new one purchased through hitachi dealer) could this mean thermic sensor is defective?
    further to my last comment. can confirm lamp voltage is correct. if thermic sensor is at fault and the fan is working can the equipment be used in emergency ie before repair.
    Genius:
  • 3,422 Answers
CLICK HERE
to view the user manual about this problem.Refer the pg nos.48,49,50..
Goodluck,
Please don't forget to rate the solution
Posted on May 04, 2008
  • Hitachi Master
  • 19,396 Answers
You should check voltage to the lamp, check also that the fan is working. The thermic sensor may also be defective.
Re set timer?
hi,
To reset the lamp hour timer do the following,
1. Power on the projector
2. press the menu button
3. Select option
4. in the option menu select Lamp time
5 press and hold the reset button on the remote or Right arrow button on the projector for 3 seconds
the lamp reset diagonal box will appear
6 using the up arrow button select reset.
Also try to reset the filter time using the same procedure
lamp reset is recommended only after the lamp replacement.
ok
Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
How to reset the filter timer of HITACHI CP-RS55 ?
(1) While the projector running, press the MENU button to open the menu.
(2) Choose "OPTION" , then press ENTER button.
(3) Choose "FILTER TIME", then press and hold the RESET button for 3 seconds.
(4) Choose "RESET" .
Feb 25, 2011 | Hitachi Performa CP-RS55 Multimedia...
There is blue shadows in the picture, my hitachi cp-rs55 just got a new lamp, but the problem is still there???? How do i solve this problem??
Hi
The problem could be caused by the connection or configuration of your video equipment. Check the following:
  • Make sure your component-to-VGA video cable is properly connected.
  • Select Component Video as the Computer Input setting in the Signal menu.
  • Make sure the connected video equipment is set up to output video to component video.
Hope this helps
Apr 01, 2010 | Hitachi Performa CP-RS55 Multimedia...
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi Performa CP-RS55 Multimedia Projector Logo
185 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
