Question about Nikon SB-28DX TTL Flash
Me wasantha i have nikon d40 camera bat i have no ttl flash lite for it i have no inof mony go to nikonsb 600 or sb 800 flash set one of my friend saygo to nikon sb28 it is ttl flash tell me can i have setsb 28 to my d40 camera or no thank wasantha.
  • 24 Answers
Posted on Dec 24, 2008
How do i turn off m zoom nikon sb 800 and switch back to ttl mode.
Go to menu on camera, then flash/bracketing, then set TTL (through the lens)
then set flash the same
Sep 07, 2012 | Nikon Speedlight SB-800 TTL Flash
Flash Nikon SB-22S works with nikon d60?
No--SB-400, SB-600, SB-800, SB-700 or SB-900.
Dec 15, 2010 | Nikon Speedlight SB-22S TTL Flash
Why does my sb-800 doesn't show the meter and ft. and doesn't have a guide GN menu?
Since SB-800 is a dedicated TTL flash, it doesn't need you to manually set the values. The flash can communicate with the Nikon cameras automatically in TTL mode.
Sep 22, 2010 | Nikon Speedlight SB-800 TTL Flash
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Settings for sb-800 to control external sb-600
    set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
    Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon SB-28DX TTL Flash Logo
    146 people viewed this question
    Top Nikon Cameras Experts
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
