Question about Toshiba 61HX70 61" Rear Projection Television
CONVERGANCE OUT OF WACK, RED & GREEN LINES ON BOTH SIDES OF SCREEN
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If convergence is skewed and or will not adjust both of the STK-392-110 IC CHIPS this set should use need to be replaced.
In most of the Toshiba sets they are on metal heat sinks with fins near the middle of the set, side by side.
There are also right in front of them some protect resistors--most will have color bands that indicate value----most common value is 1.8 ohm (like a short or good fuse---no reading and it is gone.
This is not the most easy set to get at the parts but if you want to attempt is as A DO IT YOURSELF repair I can assist you--Total parts cost on EBAY will be under 25 dollars and I can tell you what you will need and how to approach the fix.
I attach photo of what chips look like and photo of typical convergence problem.
If this information helped or told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Typical convergence chips and in front of them protect resistors.
Typical convergence problem, no two sets will look exactly the same.
Posted on Aug 22, 2010
Image on screen looks concave(middle of screen looks farther away than left or right side.)
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
May 27, 2010 | Toshiba 43HX70 43" Rear Projection...
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Crts not aligned
The only thing this should affect is the focus. After repairing the convergence go to a screen where you can see the red, green and blue seperately and adjust the lens.
May 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Green convergance problem
Sounds like a convergence amp failure. Depending on model, there may be 1 or 2 large Ics. Due to the delicate soldering involved, a tech should change these amps.Often the old part numbers have been upgraded, and small value resistors may need to be changed also.
Apr 23, 2008 | RCA P52939 52" Rear Projection Television
Dark Screen and red and blue lines
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Feb 10, 2008 | Mitsubishi VS-60607 TV
Hitachi 50UX14B rear projection: Took apart 2 clean, now red is off
What do you mean by covers? do you mean focual lens? did you replace them to there proper place (red to red, green to green, ect..). each has it's own focal legnth and must be placed on the correct gun. did you adjust (accidentaly) the red centering polls?if you did please have a tech readjust them you can end up with convergance amp overload. did you try to converge the lines? if they did not move when adjusting you may have a convergance amp problem. read my motto
Jan 17, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red green lines
have the convergance amplifiers replaced, there also may be some resistors and pico fuses to replace. the amps are STK392-120 there are two of them and they should both be replaced. have a tech do this job.
Jan 15, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba 61HX70 61" Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
