Question about Samsung SC-DC173 DVD Camcorder
The camcorder won't turn off. I even take battery out then replace it it is still on
    Scholar:
  • 122 Answers
Make sure it is not plugged into your computer. If you have the camcorder plugged in via your USB connection, then your camcorder is being powered by your computer.
Unplug everything from your camcorder and then try to turn it off or take the battery out.
Posted on Aug 22, 2010
Camcorder sony hdr-ax2000e turns itself off
hello, does it show any error code before is shuting down?
May 28, 2013 | Sony HDR Video Cameras
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
My sony dcr hc21 touch screen is not working, I went to a tech today and they chage very expensive. Is there anyway I can fix the problem ?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
  • Please make sure that you're using fully charged batteries.
  • Turn off the Camcorder and turn ON again and check the operation.
  • Try resetting the Camcorder by pressing the reset button behind the LCD panel.
  • If the issue persists again, please perform LCD screen Calibration and check if that helps. Please follow the steps below to perform the LCD Calibration.
  • Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
  • If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder. If you require any clarification or any help, please let me know. Thanks for understanding.
Apr 01, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Error C:04:00
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Shamelessly copy pasted from another forum.
Jul 29, 2010 | Sony Handycam DCR-SR40 Camcorder
Camera won,t turn on or take a charge
If there is a firmware solution on Insignis-Products, you might be able to restore the camcorder to life that way.
However, if the unit won't turn on at all...even when a USB AC charger is used where it should function normally and completely...there is a problem with the camcorder and it may be bricked.
I hope this helps and I hope your camcorder isn't bricked.
Jul 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
SDR-H40 HDD Camcorder won't turn on
I have had mine for 1 year, two months. Earlier, it booted up, and I scrolled by date to locate some older footage. Then the cam just froze up. It wouldn't power down, so I removed the battery. Replaced batterie, and booted it up, located my older footage, and it did the same thing again. Now, when I power it on, the light blinks, the "access HDD" light stays on, but it won't power up, and my computer does not see it. It is also not making that "camera on" sound that it did before. I love this camera and have never had a problem w/ it. This just happened all of a sudden. Any ideas, anyone? I even pushed the "reset" button, but even though it lights up, it won't boot up.
Feb 13, 2009 | Panasonic SDR-H40 HDD Camcorder
Open Questions:
Samsung SC-DC173 DVD Camcorder Logo
93 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
