Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
I have a Jenn Air model JJW9530DDP 30" wall oven and the temperature displayed on the screen is not accurate. It climbs very rapidly while the actual temperature in the oven is only a fraction of what is being displayed.
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: LED Display fading
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Posted on Jan 01, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
Posted on Sep 20, 2009
SOURCE: Jennair 30" wall oven display is totally off.
Yes. I could use some help. What part exactly does one need to order. Have same issue with a W2750W.
Thank you!
Posted on Oct 03, 2009
My Jenn Air oven digital display went out, what I
Apr 10, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Everything works but the display window.Is there a bulb for the display that I can replace?
jenair actually had a problem with these for a few years, they go black
or very dark
goto applianceparts.com
type in your model number, your looking for the ERC
or the clock
you cannot replace just the display
Oct 13, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Sep 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
