Question about Nikon D90 Digital Camera with 18-105mm lens
Sometimes when I first turn the camera it flashes the error "F- -" which in the manual says that the lens is not attached. However the lens IS atttched, and then it won"t shoot anything.
    Problem Solver:
  • 7 Answers
This happened to me with dirty contacts--try cleaning both on the lens and the body with a q-tip and running alcohol
Posted on Aug 23, 2010
When I turn my D40 on there is an F flashing and it says Lens not attached , can you tell me what this means and how I can fix it?
If the lens has the electronics to communicate with the camera, try cleaning the electrical contacts on the back of the lens and in the lens mount on the camera body. If the lens doesn't have the electronics to communicate with the camera, set the camera to manual (turn the mode dial to M) and set the exposure manually.
If you're not sure whether the lens has the electronics or not, tell us what the lens is.
Dec 26, 2012 | Nikon D40x Digital Camera
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
Flash not working on panasonic lumix fz7
Go into menu, setup function, turn OFF "conversion lens" or anything like that. NOTE: a conversion lens is a lens that screws onto front of lens of your camera and the flash would get blocked by it, so there is a function in the menu that turns the flash off when a conversion lens is attached to the camera. If this works, STOP PLAYING AROUND WITH THE MENU TILL YOU READ THE MANUAL. LOL.
Sep 24, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Error message is F--
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Jul 03, 2008 | Fuji FinePix S2 Pro Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
Error
Here is where you can download a copy of the manual from:
Fuji S2 Manual
This is what the manual says about your error:
If FEE in in top display: "CPU Nikkor lens other than G-type
is not set to its minimum aperture. Fix: Set lens to minimum aperture."
If FEE is in viewfinder: "Attached flash is not set at TTL
Auto Flash in “P” mode. Fix: Set the external flash mode to TTL, or set the camera’s exposure mode to “S”, “A” or “M”."
Are you using a flash that attaches to the camera?
If not, then the problem is with the aperture setting. It looks like you would have to set the camera dial to M, for Manual, and use the ring on the lens to set the aperture.
The low battery symbol looks like a battery, all black when charged, half-black as power goes down.
This looks like a nice camera, hope I was able to help.
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
Nikon D80 error
The CPU contacts on the lens can sometimes get dirty and they can be cleaned by gently rubbing them with the eraser end of a pencil.   Be very careful to not get any of the eraser rubbings into the lens.   Also, when handling a lens, don't touch these contacts, as the sweat from our hands is not good on the metal.
Sep 23, 2007 | Nikon D80 Digital Camera with 18-135mm...
Won't Take Picture Sometimes
I have the same problem with my D50. I believe it is caused by poor electrical contact between camera and lens. The contacts may be dirty but I have tried cleaning them and I still get the same error. Moving the lens often solves the problem. This led me to suspect that it is due to slight wear of the plastic mounting bayonet on the lens. This allows the lens to fall slightly and disengage from the contact pins. My 70-300mm lens has no problems since it only uses a few pins.
Mar 21, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D90 Digital Camera with 18-105mm lens Logo
201 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
