Question about Samsung LN-R408D 40 in. LCD HDTV
I have a Samsung LN-R408d Lcd T.V. It has sound and picture, but the picture is weak and distorted any movement on the screen has trails kind like it's in slower motion.
  • 3 more comments
  • Stan Lee Aug 23, 2010
    Where are these capacitors located? are they on the inverter board? Thank you for helping me
  • Stan Lee Sep 03, 2010
    I replace the power supply with a used one that I found on line last week and that wasn't the problem.I also found a used LCD controller/Tcon board and installed it today and that fixed my problem. The picture is great now.
    Both of the Guru's was way off the mark.
    It was the Tcon board
    It was the Tcon board..... Guru
  • Samsung Master
  • 11,800 Answers
The image is dark because the back lighting is very limited  and the image has trails because the pixels can't be switched fast enough.  All this are clear indicators that this happens because the power coming from the source is low: open the back of the tv and test the power source with a voltmeter. Look for defective capacitors or shorted coils and replace them if you have even the smallest doubt.
Posted on Aug 23, 2010
  • Samsung Master
  • 5,138 Answers
You either have Bad capacitors or the inverter board is bad which in that case companys do not have ant extras in stock Bad capacitors will be vented, or puffed up on top, 1000uf 16v
220uf 10v 330uf 10v
  • 2 more comments
  • ladywinn
    ladywinn Aug 23, 2010
    Problem could be your Display Panel and its the part they do not stock, Google to this Website
    Encompass Parts Distrbution and Type in your Model number for list of parts /Prices
    Also browse EBay under Electronics TV/Parts
    Bad Caps will be around the power supply board.
  • ladywinn
    If your model # is LNR408DX, Then Encompass Parts Has Free Service Manual you can Print out online Look on left upper side of Page Click on where it says LNR408DX.pdf. They also are showing 265 Parts for this Model.
    I went to Encompass Parts site and no service manual is availible. Am I to be looking on the main power supply or the secondary power supply board. I was able to locate a inverter board online for about $55.
  • ladywinn
    ladywinn Aug 24, 2010
    I went to Encompass Parts Distrbution and they are listing Free Service Manual for Model #LNR408DX and on the first Page up on left hand side it says service manual and under it is printed LNR408DX.pfd this is what you click with mouse to print out service manual,Heres another thing it could be your Display Panel that is going Bad causing slow picture movement,alot of time when this happens picture begins to stand still burriie looking but sound is on but does not match picture being produced.
How to master reset samsung LN-R408D
Unplug the TV from AC mains wall socket, and re-plug it back after 30 minutes or so. This must make a hard reset to this set.
Aug 19, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D no display
The part labeled cp with a p on it has a black burn mark in the middle of it on mine!
I have a samsung model: LN-T4061FX. when turning on the tv, it has a distorted picture, the sound is good. if i smack that **** out of the top of the tv after multiple tries the screen will eventually
flext tab bond is the most likliest cause. They tend to lose their bonds and then usually hitting the top edge of the screen will lock it in. Flex tab issues will make part of the screen take on distortions and slow response of the pictures movements in the screen
Aug 05, 2012 | Samsung Televison & Video
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
My Samsung LN-R408D 40 in. HDTV LCD have issue power turn off itself after being on 1 or 2 hrs. Any suggest would be great
It could be the power chord thats gone bad. I have the same television. Mine is broken as well. Would you be willing to part wit it?
Oct 13, 2010 | Samsung LN-R408D 40 in. LCD HDTV
Gray screen
Try unhooking the LVDS cable from the controller board and see if it does the same thing. If so you need to replace the LCD panel.
Oct 27, 2008 | Samsung LN-R408D 40 in. LCD HDTV
LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Mar 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LNR408D 40 in. HDTV
Sounds like a backlight going bad or possibly the inverter. Check each backlight first for dark discoloration on the ends. If that checks out good then it's the inverter.
Mar 17, 2008 | Samsung LN-R408D 40 in. LCD HDTV
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-R408D 40 in. LCD HDTV Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
