Question about Kalorik Vacuums
I have Kalorik ICBM ice maker. The unit stops after about 5 min and both the right and left top red lights blink.
  • jeffvg22 Aug 22, 2010
    YOU HAVE NO IDEA about the ice maker you suggest that you know about. It is a portable Kalorik ICMB. Give me a proper answer or refund my money.
    President:
  • 1,768 Answers
1. This issue may be due to a clogged water filter.
You didn't provided the model number so therefore I am assuming this is a refrigerator.
2. Your icemaker is in need of service. If the filter has been there for more than 6 months then is is a pretty good chance that it is clogged and need replacement and the indicator lights are telling that they need replacing and are stopping performance to safeguard against you getting contaminated water in the ice tray.
This is only an estimated logical guess here from the information provided. I hope this helps. Have a great day!
Posted on Aug 23, 2010
    Genius:
  • 1,478 Answers
If your ice maker is not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Aug 22, 2010
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
What is the blinking red light on the top of the vacuum
red light blinks when filter needs to b change hope this help thanks for reading
Jan 06, 2012 | Euro-Pro NV31 Infinity Vacuum
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Where can I buy parts for a Kalorik bagless vacuum cleaner? It looks like the model pictured above, but the # on the manual is USK VC2.
Kalorik ' Parts and Accessories ' Discontinued ' item VC16107
Here is their site, it looks like the canister vacuum is discontinued.
If this is not adequate information, you can find several contact options on this page.
Gary
Feb 16, 2011 | Kalorik VC16107 Bagless Canister Cyclonic...
Just purchased the unit 2 weeks ago. Worked great. Last night I left it plugged into an outlet - but turned "off". This AM the unit comes on; timer showing default @ 5 minutes; however, no...
I wonder if you are talking about a coffee maker?
It ended up being listed under Vacuums!-
Sorry about that-- It sounds like you arehaving trouble getting the maker to boil water, and move it thru the maker, no?
Anyway-- I don't see why leaving it 'on' all night should have done anything wrong-
But maybe the Coffee maker guys know more about this repair than we do in Vacuums-
Sorry about that
Mack B
Jan 27, 2011 | Vacuums
Roomba would run for 2 seconds and then stop it Plays 4-note song as Power button blinks RED. if I remove the battery and then try again, it repeats the same.
Probably, the battery has little service life left and should be replaced. You might let the machine run until there is no light showing at all, recharge fully, then try using it again. If you know someone that has a similar unit, try swapping batteries to check. Good luck!
Oct 13, 2010 | Roomba Robotic Floor Bagless Vacuum
Mine is a new upright Meile power plus. When I have it
Sounds like you have a clog. There are screws in the back of the vacuum that you can undo and find the clog. If you need assistance or if that doesn't solve the problem.
http://miele.com/locator/locator_new.asp?nav=800&snav=800&tnav=800&oT=7
^this will help you find an authorized Miele repairshop.. you can also call them at (888) 785-2828
Aug 31, 2009 | Miele Powerhouse Plus Bagged Upright...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Vacuums Logo
109 people viewed this question
Top Kalorik Vacuums Experts
JoeVacs
Are you a Kalorik Vacuum Expert? Answer questions, earn points and help others
