Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing code f-28, thanks - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F28 is a communication error between the Central control unit (CCU) and the Motor Control Unit (MCU). To resolve this issue unplug the washer and start with checking the wire harness connections to the MCU, motor and the Central control unit (CCU). Also make sure that the connections of the CCU Board are within the housing and all grounding switches are engaged properly. After this is done plug the washer back in and check the CCU & MCU, check that the motor is running, and check the door switch. If motor is not running then it is the MCU that is causing this if it turns then it is the CCU, replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
My selects 28
Did you type the error code correctly, is it code 8 or 28? And you need to be more specific (what)..which Select 28 you are talking about.
Nov 22, 2016 | Televison & Video
Dtc 14 17 18 19 28 29 30 32 33 34 35 36 46 51
TYPE: OBD 1 Code 13 etc & read for hours
Could Type: 1989 Cadillac OBD 1 Codes
It's all there on the internet
Codes,Problems & Solutions--- dozens-- if not
hundreds of sites,forums,tech info,etc
Apr 02, 2014 | 1989 Cadillac Seville
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
Screen (f-28) and keep flashing
call for service this is a covered repair. you have something wrong with your motor or a loose connection somewhere. You say this is brand new if it is less than one year it should be 100 percent covered
Apr 23, 2009 | Kenmore Washing Machines
Canon 28-135mm IS lens makes clicking noises
Check out the mirrors on the camera, This is a pretty popular problem with the canon cameras. The lens gets dirty in the camera and it sends a error code
Feb 08, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Duet Sport Washer fault code F-28
f-28 code is a serial communication error between the central control unit-ccu- and the motor control unit-mcu-. depending on the age under one year the unit should be under warranty, if so call a service man that care of the problem in warranty. if the unit is over one old you can remove the top and check all connections between the ccu and mcu.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2plus washer
Error F 28 is your heater and it will not unlock because of it.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1176579&PPStack=1
Here is the part info thanks
Sep 21, 2008 | Washing Machines
Shoe moung of sb 28
http://www.sdcamerasolution.com/index.php?p=product&id=240&parent=22
Buy it from there and replace it..
May 15, 2008 | Nikon SB-28DX TTL Flash
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
