Question about Kenmore Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
  • Kenmore Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Posted on Aug 22, 2010
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
i thought I responded to this.
make sure the air gap in the kitchen plumbing (if installed is clear). Also check the kitchen drain is not blocked. If using garbage disposer in sink, then make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Model 665.13732k600 seriel FT4610713 dishes are not getting clean, they look like they have a film on them. Kenmore Ultrawash Quiet Guard Deluxe
The film is the stuff and the old soap backing up in the dishwasher. There is no cure for this. You can have them come out and it won't get fixed because it will happen again. They did not put a large enough drain/disposal on the models. Essentially you are eating old soap - goodness only knows what is in it.
Jan 01, 2010 | Kenmore Dishwashers
Kenmore quiet guard standard ocassionally does not use/mix all soap supply and does not get dishes clean. Any ideas?
MIne did the same thing a couple of times. I found that I had put a casserole dish on its side in front of the soap dispenser...so it opened, but the sprayed water could not get to it.
Hope this helps.
Aug 03, 2009 | Kenmore Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
972 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
