Question about ASUS P4S800D-X Motherboard
My ethernet drivers are not installed. How do I update without internet acces?
    Sergeant:
  • 203 Answers
If you have a Wireless Modem then you can buy a Wireless Dongle or Card for your P.C., or use a friends internet and download drivers etc.. on theirs and copy to disk or memory stick etc...
Posted on Aug 22, 2010
Cannot connect a pc to internet
Get onlineand got to www.google.com In the google search box type: "CompaqSupport" or "hp support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.Try downloading the Network Drivers, LAN Drivers, Chipset drivers. The ethernet controller will probably be solved with one of them.You can also try Driver Guidehttp://www.driverguide.com
Apr 29, 2012 | Compaq Computers & Internet
My computer doesn't have its pci.sys,#512;Ethernet Controller installed and i can't connect to the internet to update it what do i do?
You will not be able to connect to the internet without the ethernet driver.
To update the driver manually refer to the steps below:
- click start > run then type "devmgmt.msc" - once device manager is open look for network adapters - click the plus sign at the left side then right click on the driver then select update driver online. - it will look for a compatible driver for your LAN card.
hope this helps.
Jul 01, 2011 | Computers & Internet
Unable to use LAN
if you are reffering to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
also you might check
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 12, 2011 | Computers & Internet
I have an old IBM t60 Thinkpad I am trying to (clean) install XP home edition. The OS is installed but I have no internet connection. I am missing drivers for Network controller, PCI device, SM Bus...
You can try to use an Ubuntu 10.10 CD, and when you are done with the install you will have access to the web without needing any drivers.
Then go to the web and download your XP drivers if you still need to.
Would recommend you use Ubuntu as it is much better OS than XP and runs great on T60 very solid.
Y.
Feb 04, 2011 | IBM ThinkPad T60 Notebook
Missing video controller,multimedia controller,smbus controller,pci controller,ethernet controller
the driver should be on the disk supplied by your isp internet service supplier
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
hope this helps
Jan 13, 2011 | Computers & Internet
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
I like to download ethernet controller driver but not from driver detective as this require an internet connection to complete what i want to do.
you nedd to go to a website and download an updated ethernet controller driver are useless because you can't even access the internet without the ethernet controller, unless you have a second PC already hooked up to work with the internet, then make a copy of the ethernet driver, and then copy it onto the original PC to get it acces the intenet. Most people may have to go to a computer repair store and ask if they can buy the ethernet controller driver for their OS and PC on a CD or flashdrive, or instead, but an external Ehternet controller device and connect it to your PC via USB.
Jun 19, 2009 | Compuware DriverStudio (dd-rstd-np/nm31)...
Cant access internet without network adapter operating
You can download drivers at
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8400&os=WW1&osl=en&catid=&impid=
If internet is not working , then u might have received a CD with when u first got ur system, it has all the drivers that ur looking for.
If u cant find the CD, then contact Dell Technical support, they will send u one free of cost.
May 24, 2009 | Dell Dimension 8400 PC Desktop
No conection to internet by local network
hi! there,
if you have *********** board installer,install and the wizard will find your ethernet driver if this buit in ethernet,but if you have an external pci enthernet device go to device manager,left click and click the properties of fast ethernet pci device,try to update your driver on website.device maneger can find on control panel under
system,click hardware,click network adapter,click properties and click on drivers and update your driver.have a nice day.
Apr 15, 2009 | Computers & Internet
ASUS P4S800D-X Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
