Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
There is a middle black strip between the doors,, it is very HOT
  • KitchenAid Master
  • 43,501 Answers
This is hot to keep condensation off of it...if it is too hot then the internal t-stat has gone bad and is not shutting it off...
heatman101
Posted on Aug 22, 2010
  • 4 Answers
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. Ihad inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Posted on Aug 27, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: It's extremely hot around the door frame of
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Posted on Sep 24, 2011
Leaking dishwasher
The rubber strip that the door connects with is crudded up with junk. Get rag and hot water in bucket. Open door. Look for rubber gasket shaped like an upsidedown U, the sise of the door. It wont be black in places because of all the build up of soap scum. Wash this off till it black again. Wash door where it meets this gasket.
Good Luck.
Jan 11, 2014 | Frigidaire Dishwashers
It's extremely hot around the door frame of the refrigertor mainly the middle strip. Everything else is fine.
heatman101
Sep 10, 2011 | Kenmore Side by Side Refrigerator
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Black strip at the middle of the Screen
if this set has a transformer to power it ,try batteries instead if this cures it replace trans farr64
Apr 27, 2009 | Televison & Video
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
370 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
