Question about AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor / Century B124
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
  • 8,404 Answers
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Posted on Aug 27, 2010
Switched to new AO Smith B230SE motor for pool pump. Old motor had left-hand screw that held impeller to shaft. New motor does not have an opening for screw. Will impeller be fine without screw?
Did you try the Century A.O. Smith B230SE motor without the center screw? I'm having the same problem and I'm asking the reseller for advice. It would be great to know if I need the center screw is required? The impeller screws on the shaft, but is the center screw required?
Sep 17, 2013 | A.O. Smith SQ1102 Pool Pump Motor
How to remove impeller
i think they screw on and the screw only locks it in place
Mar 22, 2012 | AO Smith SQ1152 Pool Pump Motor
Hi, I have a QC 1072 A.O. Smith pool pump motor. How to get the impeller off? Which direction does the impeller spin off? Where to but impeller and seal? Thank you very much Greg
The impeller is just screwed on the shaft. COUNTERCLOCKWISE to remove. Some have a screw in the center attaching it to shaft. This is removed by by turning CLOCKWISE.(reverse threads) Remove back cover and secure shaft with a wrench. There are flats on the shaft to hold it. You might need a large pipe wrench to loosen impeller. Wrap with rag so you don't damage impeller.
May 18, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
My ao smith 1.5 hp pool pump is leaking. A washer about an inch round popped off and is cracked and broken. I dismantled pump and took off the 4 long screws to get to the washer. At this point I'm trying...
BUMMER THE IMPELLER IS BROKE U WILL NEED A NEW ONE. USE TWO BIG SCREW DRIVERS AND PRY TO BREAK THE IMPELLER.. THERE IS NUMBERS ON THE IMPELLER USE THESE TO GET THE RIGHT IMPELLER FOR YOUR HP MOTOR REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 21, 2010 | A.O. Smith SQ1102 Pool Pump Motor
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Aug 09, 2009 | AO Smith Pool Pump Motor Hayward 2 Speed...
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor  / Century B124 Logo
365 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
