Question about Samsung LN46B650 46/49.5 in. LCD HDTV
I need to remove the pedestal off a ln46b650 flat screen for wall mounting. I can't remove it' Hpw do I ?
4 Suggested Answers
  • 718 Answers
SOURCE: LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Posted on Mar 16, 2009
roety
  • 585 Answers
SOURCE: We had the tv mounted on the wall and now want to
Hi my name is Roety,
I can help you with your issue ,
The pedestal slides up into the back, and is held by 4 or 6 screws thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Nov 09, 2009
welcomejee
  • 10594 Answers
SOURCE: I am wall mounting my
Is it Samsung LN-S4041D model as shown in question or any other model?
Thanks.
Posted on Aug 05, 2011
How do I remove the base pedestal plate from our Conia CL3201FHD television so we can wall mount it?
most have a trim plate at the back of the stand that when removed shows up 4 screws that can generally be used in the wall mount bracket holes
Dec 12, 2015 | Televison & Video
HOW DO I REMOVE THE PEDESTAL BASE TO WALL MOUNT THIS TV? HAVING LOTS OF TROUBLE! HELP!!
Lay the tv on its face and look at the back of it where the pedestal is attatched,there will be some screws holding the pedestal to the tv. may be on the bottom of some brands.
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Samsung LN46B650 46/49.5 in. LCD HDTV Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
