Marantz applifier SR5500 clicks off and on for no apparent reason after being on for a while. making repetitive clicking noises
  • 3 more comments
  • uhale Aug 23, 2008
    Same problem, Marantz receiver SR8400 randomly switches off and makes repetitive clicking noise. uhale@hotmail.com.
  • lathamrobert Jan 12, 2009
    i had the same problem with the marantz sr 5500. i changed the power cord, and now i haven't had the problem since, so give that a try...
    i also had the same problem with the marantz sr 5500... try changing your power cable, this is what i did and i haven't had the problem since.
  • Anonymous Jan 27, 2009
    Same problem here.  The Marantz SR5500 receiver makes clicking noises and won't turn back on.
  • Toca Jan 29, 2009
    How do you replace the power cord?
3 Suggested Answers
cyrylthewolf
  • 143 Answers
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Posted on Nov 03, 2007
cjackHD
  • 71 Answers
SOURCE: Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
My antenna jack on a marantz sr5500 broke. how do i replace it and where can i find one
If you still have the connector and if your Tuners board is not broken, you can solder it back on if you are careful. If not replace the whole tuner.
Part# 90M-AV000350R
Jun 21, 2012 | Marantz SR5500 Receiver
Cant play ps3 digital audio through Marantz SR5500
Check to see if there are any software or firmware upgrades for your receiver and you PS3. This could be a handshaking issue that is easily corrected with an up grade.
May 02, 2012 | Marantz Audio Players & Recorders
Marantz SR5500 B speaker setup problem
are all the speakers connected 1.5s
all the same watts helps
is that one with an inbuilt amp ?
what a mess or connectors at the back of one of these
Model SR5500 User Guide - Marantz
us.marantz.com/DocumentMaster/US/DFU_SR5500_Final_Eng.pdf
Apr 16, 2017 | Marantz SR5500 Receiver
My SR5500 from Marantz has a problem. It suddenly powers off and then a clicking sound is there. It then does not come on
HI...
Are the speakers all connected properly and set to the right pair ( A or B)?
Do any lights show on the front panel such as "Stand-by"?
Aug 16, 2010 | Marantz Audio Players & Recorders
1997 Dodge Grand Caravan heater blower makes clicking noise
take out the blower motor
if the bearing is ok
use a vacuum cleaner to suck out the debris in the piping
Apr 28, 2017 | 1997 Dodge Grand Caravan
Can't be recognized.
If the noise is like a repetitive ticking or clicking. Well, the sorry to say that the hard drive had crashed... which makes the noise... And sorry to tell you that you cannot do anything but to buy another...
sorry... Fixya!!!
May 21, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
May 19, 2009 | Marantz SR5500 Receiver
Marantz SR5500 Owners Manual ?
An English version is available from the Marantz USA website as a PDF download.
Open the following link:
http://us.marantz.com/689.asp?category=AV&model=SR5500&go.x=11&go.y=14
Then click on the "SR5500 User Manual" link listed under the "Manuals and Documents" heading
Dec 21, 2008 | Marantz SR5500 Receiver
Marantz model 5500 AV Surround Receiver
Hi, hope this helps, try (1-800-remotes), these guys have a wide selection.
Oct 22, 2008 | Marantz SR5500 Receiver
Can't find the cause for clicking noise and BSOD
From what I've read, the "clicking" is a sign that the hard drive is about to fail. The cause is using two devices (hard drives, CD-ROM drives, etc.) with different read/write speeds on the same IDE cable. For instance, you MUST not have an ATA100, ATA66, or ATA33 hard drive or CD-ROM drive on the same IDE cable as a faster ATA133 hard drive. Hope this helps
Mar 16, 2006 | Maxtor MaXLine Plus II 250 GB Hard Drive
251 people viewed this question
 Grubhead
Grubhead
