GE rf modulator cat number AV 20182
This modulator just stopped working. Do they "burn out"? Is there anything I can do to test it or fix it? Or do I just replace it?
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't hook up Magnavox DVD/VCR to TV unless I have a RF modulator
Since I haven't heard back, I must clear my queue - call 1-877-philips for help
Posted on May 30, 2008
SOURCE: i also have the problem with the TV,,,,the TV uses
Sounds like you are getting RF feedback... this is because it is a lower quality RF Modulator. You could try to get some "Ferrite" "Rings" or Snap on "Blocks" and put the around the cables to mitigate this, or you could try somehow making sure all the earths are good. Reorientate the RF box further away,, even try wrapping it in Aluminium Foil.
Posted on Feb 15, 2010
Is there anything I can diagnose '91 volvo 940 turbo myself? Mechanics say can't find anything wrong with car. It stall like losing power fuel pump relay & ignition fuse get hot sometimes
the pointer is the hot ignition fuse
that indicates excessive current draw almost to the point of blowing the fuse
with the car stalling ( stopping /cutting out) I would be focusing the attention on the electronics of the vehicle in areas of the ignition control module or the ECM itself
there could be components that ore overheating and failing or shorting and overheating and failing
The ECM you can test by getting a known good unit and substituting it and the ignition control module can be like wise replaced or checked by an accredited auto electrician who has the test equipment
Lastly you can go to autozone and see if the fault codes can be read ( free) or to an accredited service shop that has experience on volvo cars ( may cost for the reading) and fix what faults show up
Jun 05, 2016 | Volvo Cars & Trucks
Dash lights and over head light stopped working. Could this be the headlight, dimmer switch?
It could be ,depends on the make,model an year vehicle. Best to test power B+ voltage an grounds > I don't know what if anything you know about automotive electronics. You can go to youtube an check out some videos on basic automotive electrical testing an trouble shooting . Some newer vehicles the dash lights are controlled by a module , BCM - body control module ,SJB - smart junction box etc.... You can go to www.bbbind.com/ for free wiring diagrams an see what all is involved in the circuit. I don't like to see people waste there money just replacing parts . I have been fixing vehicles for over thrity years . Started at a Chevy dealer right out of a two year automotive program back in 1984 .
Dec 17, 2015 | Cars & Trucks
1991 Ford F-250 burns up TFI modules after about 50 miles
I found the so called famous ford trucks to be no more than junk and problem after problem.
Jun 18, 2017 | Ford F-250 Cars & Trucks
My power windows and wipers stopped working on my 1995 ford explorer
Your wiper system and your power windows share several different circuits and components including the Battery Saver Relay, The Inadvertent Power Relay and the Generic Electronic Module. Each of these circuits need to be tested individually to determine the location of the failure. Chances are that one repair will fix both your power windows and your wipers. However, locating the actual cause is going to be the tough part and wil require some considerable skills in diagnosing automotive electrical systems.
If you think you can handle it yourself and you have the testing equipment necessary to diagnose the circuits, I can guide you through it.
Nov 13, 2011 | 1995 Ford Explorer
1993 Dodge Dynasty. Wipers stopped working. Replaced fuse. Still not working. Replaced Body Control Module(BCM) located inside kickboard(passenger side). Still not working. Tried a second BCM, didn't...
BCM's are part number specific to your particular vehicle so unless you got from a dealer and had the dealer flash it for you none will work.
Caravan's had the same problem with their bcm's
Did you test the motor to see if it was working before you got the bcm's?
Did you test the wiper motor switch?
Also test the wiper motor relay.
Apr 01, 2010 | 1993 Dodge Dynasty
Washer stopped working and smells like it's burning
This would be the motor coupler that has failed common problem and easy to fix. There is a video ( whirlpool style) that will walk you thru the troubleshooting and replacement at www.appliancehelponline.com/servicemanual.html
Mar 27, 2010 | Estate TAWS850PQ
Blower will not start, will not fire
Doubtful. Clean the bolts and re-mount but I doubt that'll fix your problem. Check spark with an in-line spark checker. Be sure you have the right oil/gas mix...or you will burn it up. How did you check compression, what is the reading? Anything less than 100 means the piston ring is stuck.
Aug 15, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Cheverlet K1500 no spark
two more things related to spark one is the ignition module, two the distributor pickup assmbly, and last but not theh least check and make sure the distributor rotor is not burned up
check the pick up coi for continuity, using an omh meter you can use theh omh meter to test the distributor rotor also if they test out ok then replace the ignition module.
Nov 15, 2008 | 1992 Chevrolet K1500
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
