Question about Canon Office Equipment & Supplies
I have a canon D2400U scanner. When trying to scan a photo, the scanner does its little back/forward shuffle then slowly drives back, past the start position until it jams and the belt jumps on the gear. I have switched off, restarted,etc but can't get past this point. Using windows XP.
    New Friend:
I just had exactly the same pb; could find that the 12V dc power unit was bad; changed it and then everything is OK
It looks like the quality of 12V current isn't good (regulation failed)
For replacement I actually used a PC Power unit, and reused the DC cable (with the ferrites) for the scanner's plug isn't a standard one.
Posted on Apr 12, 2013
2 Suggested Answers
SOURCE: Scanner is jammed
There is usually a scanner lock button on these units, either located under the Auto feeder on the left side, or on the left side of the machine
Posted on Jul 17, 2009
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
Tip
How to scan a photo
after you have a scanner in your home you need to install drivers and connect the scanner with your computer. the photo you would like to can just place over the scanner background and give the command of scan from your computer automatically or start scan manually from the scanner and you have to save the scanned photo in your favorite folder of your computer, to use it afterwards
on Jul 16, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
How do I get the Canon image runner 1023if to scan documents? I have followed the instructions provided by Canon (what little there was) loaded the drivers, (as per Canon) and still cannot get past the...
Try using different software for scanning. e.g. Photoshop Select the right scanner, for Canon you usually see WIA. Then import image and select Canon. New window will pop-out and you can start scanning. Be sure to press the SCAN button of the machine before scanning.
Jan 26, 2010 | Canon imageRUNNER 1023iF Black and White...
I was getting streaking across all photos that I was scanning. So bad that I researched getting a new scanner. Then one day it started working just fine. Now today I scanned some slides and when I tried to...
sounds like the scanner is skipping pixels. that is usually a sign of malfuncting. the best solution is get a new one. cost of getting new one is much cheaper to repair it.
Oct 17, 2009 | Canon CanoScan 4400f MultiFunction Color...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Scanner buzees and moves slowly and scan's all photos as one
I fixed the problem by updating a driver I found in the Epson site. It woeks great once again.
Mar 23, 2009 | Epson Perfection 3170 Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanning 4 x 6 photos
Try reinstalling the scanner driver or scanning in different resolutions.
The stretching is probably caused by the scanner motor, it isn't moving at the right speed. It also can be a hardware problem inside the scanner.
Feb 06, 2008 | HP Scanjet 4400c Flatbed Scanner
Scanning slides -
Do try reinstalling the fotware this is where the trouble lies.
Or
Save the scans and in a suitable photo Editor revers the image Neg to Pos
Dec 29, 2007 | Epson Perfection 1660 Photo Flatbed...
111 people viewed this question
old marine
old marine
