Question about Jenn-Air Ovens
My jenn-air model W30400WC wall oven clock display went very dim; do i just replace it ,or do i have to replace the power relay board also
5 Suggested Answers
  • 3 Answers
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
  • 114 Answers
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
Posted on Sep 20, 2009
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Posted on Mar 19, 2010
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
Jenn-air expressions wall oven clock went dim, now out completely
This may be no help at all but;
Similar ovens have had problems with timer components going bad (overheating) and causing this problem.
First contact Jen- air customer service about a recall or replacement timer board, if that doesn't work remove the timer board and look for a discolored or leaking capacitor, These capacitors are less than a buck as opposed to over a hundred for a replacement board. If you don't want to solder it yourself find your friendly local geek from the radio or electronics club or get a recomendation from the local electronics parts house,
Nov 08, 2009 | Ovens
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
89 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
