I HAVE CREATE ACTION VOIP ACCOUNT AFTER 6 DAYS.BUT THIS TIME I FORGET MY PASSWARD,my action action voip account name sanikumbla008
    Scholar:
  • 122 Answers
Hello sanikumbla, You can recover your password at the following link:
Please rate this solution if you found it helpful or post a reply with any further questions regarding this problem. Thanks! Edward
Posted on Aug 22, 2010
Name favorit uncle
I cant open my yahoomail account my yahoo mail account abdurr97@yahoo.com and passward is 01111969but i cant open give me the solution as early as poosible
Nov 26, 2013 | Yahoo Mail
How can i get my action voip password, becoz i forget my action voip password , and unable to access my email id by which i register in action voip, please help me to get my password. avrp7361
CHANGE PASSWORD
It is wise to change your password for security reasons regularly. To do so, just go to the 'my account' area by logging in. Then choose the 'Settings' tab. You will find the password change option on the bottom of the page.
Apr 08, 2013 | Computers & Internet
CHANGE PASSWORD
I am trying to open my face book id but its not opening the face book tells me i using incorrect passward but in reality i am using correct email and correct passward.why its happening to me
If you are sure about your password and email (case sensitive) then i think your password changed by other one. you can reset your password by using forget password option.(if you can login in your email through which facebook account was created.)
Aug 30, 2010 | Computers & Internet
I Cannot login in to actionvoip because i forgot my password
how can i get my action voip password, becoz i forget my action voip password , and unable to access my email id by which i register in action voip, please help me to get my password.
Aug 19, 2010 | Computers & Internet
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
I have Nokia E72, how can I connect to VOIP service in our office?
go to Tools > Settings > Connection > SIP settings
Profile name: any
Service Profile: IETF
Default Access point: select your access point
Public user name: sip:your-voip-ext@voip-server.com
Use compression: No
Registration: select your preference
Use security: No
Proxy server: empty/no settings
Registrar server:
> Registrar server address: sip:voip-server.com
> Realm: asterisk
> Username: voip-ext-no.
> Password: voip-password
> Transport type: Auto
> Port: 5060
Then go back to Connection > Internet Tel.
create profile and select the SIP settings you just created.
May 06, 2010 | Nokia E72 Smartphone
I need to creat my acount in yahoo messenger
Hi
Here is how you can create your yahoo messenger account.
1) Download and install the Yahoo! Messenger program.
2) Go to the Yahoo! Sign Up page.
3) Enter in the necessary personal information in the "Tell us about yourself" section. You must give Yahoo! your name, gender, birthday and location in this section.
4) Choose the identification name you would like to use on Yahoo! Messenger and type this name in the "Select an ID and password" section. In this section, you must type in the desired Yahoo! ID name and the password you will use to log into the account.
5) Fill out the security information listed in the "In case you forget your ID or password" section. Enter two different questions and answers that could be used to retrieve your Yahoo! Messenger account information if you forget the sign in name and/or password for the account. You also have the option of entering an alternate email address in this section although doing so is not necessary.
6) Type in the security code at the bottom of the page and agree to the Yahoo! terms and conditions. Then click "Create My Account." You will be asked to confirm the creation of the account on a new Web page. Click "Continue" on this page and your Yahoo! Messenger account will be activated. You will then be able to sign onto Yahoo! Messenger.
If you have some more questions, please let me know.
Otherwise, please leave positive rating and feedback.
Apr 28, 2010 | Yahoo Messenger
I can not log in to my account. It says my password is wrong even though it is not. I have not been able to get anyone at fb to contact me.
u could be typing your passward wrongly
type it correctly
even though if it does non work,click on "Forgett Passward" or "Passward recovery " option
then follow the security questions that u had answared at the time of account making.
These questions could be of like:
1.What is your pet's name?
2. What was the name of your first teacher?
3.What is your mobile no.?etc.......
Answer these questions correctly on the basis of your memory to get get your passward resetting option.
If it does not works tell me again, i will try to get some codes for u to get the passward recoverd.
Mar 30, 2010 | Computers & Internet
Can I reactivate a deleted yahoo e-mail account, if so, how?
If your yahoo account was just deactivated (due to non-use or your deletion attempt) within last 90 days, you can reactivate it by logging in again. However, once deleted fully or beyond the deactivated 90 days period, there is no way you can recover that account. However, you can create a new account with that name. FYI: http://help.yahoo.com/l/us/yahoo/edit/changing_users/edit-23.html
Jul 13, 2009 | Yahoo Mail
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
