Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
HE3t Perfectly level on solid floor andspuins out of balance. I suspect the front/rear tube counterweight, but not sure.
    Champion:
  • 245 Answers
If it is brand new make sure you take the four shipping pins out of the back.
Posted on Aug 22, 2010
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight,...
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Oct 12, 2010 | Audio Technica AT-PL120 Turntable
I have a tasco luminova 900x114 telescope and seem to have a problem balancing it. The counterweight seems too light and the scope falls away even with the weight right at the end of the rod? have you ever...
Possibly they included the wrong size counter weight? Normally you can balance the scope with the counterweight included with the scope.
There are TWO balance directions-
One uses the counterweight--
The other depends on the position of the TUBE in the scope rings front to back. BOTH directions should be in balance.
Mar 15, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
I have a Whirlpool front load washer wfw8400tw02. I have had 2 service calls to checkout the out of balance condition. The first tech moved a drain hose inside the machine. The second one tried leveling...
being level is not quite as important as being solid on floor or on solid floor..if on a pedistal remove bottom drawer and be sure all mounting screws are tight ..with drawer adj all legs up until they are up tobottom of pedistal ck washer by trying to rock if movement detected adj FRONT feet only as much as needed to reduce motion ..same applies without pedistal if is a noise issue more than an unbalance issue suspect shocks supporting tub try removing bottom panel and being careful allow unit to run and try with one hand to isolate which shock..changed 1 friday
Dec 08, 2008 | Whirlpool Washing Machines
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Whirlpool Duet Washer
dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. Catriver..post back.
Apr 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
