Question about Whirlpool LXR6432JQ Top Load Washer
My machine will agitate but won't drain or spin. A few weeks ago, I discovered sticking a screwdriver into the hole (directly under the lid) would make contact and would allow it to drain and spin. Its no longer working (even with the screwdriver). What now?
    Champion:
  • 245 Answers
The thing you were poking with a screwdriver is called a lid switch. That would be bad. The cost is about $45.00. You can buy one online or from a appliance parts distributor. Good luck! Make sure you rate me.
Posted on Aug 22, 2010
Whirlpool LSQ9544KQO won't spin
if it fills with water and then nothing check the lid switch,if it's bad it won't do anything but fill,some will agitate but then no drain or spin,the easiest way to check it is open the lid a few inches and close it,do this a few times,if you don't hear a clicking sound the switch is bad,or open the lid and stick a screw driver into the hole on the right side where the strike from the lid goes into,if it doesn't click when you push it down and let it up it's bad,part number 3949237 and it's around 50 dollars.watch this video,it's a different lid switch but changes out the same way.
http://www.youtube.com/watch?v=MFsvLiuTniU
you can also stick a jumper wire into the two outside wires to check it,flip up the top console,you'll see the lid switch connector on the right side plugging into the top of the frame,unplug it,stick the jumper into the connector that unplugged from the frame and it will have three holes in it,the middle is ground so stick the jumper into the two outside holes,set the timer to drain and pull out the timer,if it starts to drain and spin then you know the lid switch is bad.hope this helps.
Jun 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a electric whirlpool thin twin. It fills with water and agitates...then nothing. No drain, or spin.
check the lid switch,open the lid and on the right side you'll see a hole in the top panel,stick a screw driver in it,push down,you should hear a click,or close the lid and open it a couple of inches and close it,do this a few times,no clicking sound bad lid switch.
Sep 12, 2011 | Whirlpool LTE5243D Top Load Stacked...
The cycle does not go
The typical problem is a bad water pump. Your washing machine would still do the agitation part, though. It would just stop when it came time to drain the tub. Replacing the water pump every so often is almost routine maintenance on old machines. It's inexpensive and fairly easy.
If it won't agitate, there's another possibility. You have a safety mechanism that keeps the washing machine from doing the spin cycle when the lid is open (you wouldn't want your kid reaching in there while the machine is spinning). I think most machines will agitate with the lid open, but some machines might not - while there is a slight safety risk, many people want to add bleach, laundry additives, etc, while the machine is agitating.
There should be a pin on the lid that goes into a hole and pushes the safety latch when the lid is closed. If you're missing that pin, you need to replace it (that would be a good problem, since the replacement pins are very cheap).
Once the machine fills up, push a screwdriver into the hole a little ways and see if the machine starts working.
Apr 30, 2011 | Thomson Washing Machines
I have a Kenmore Ultra II 90 series washing machine (#11092561400) it fills & agitates but wont drain & spin/rinse? Any solutions.
lift the lid up a few inches and close it down a few times,if you don't hear it clicking you have a broken lid switch,also try to stick a pen or something in the hole on the top and see if it spins,let me know what you find
Aug 27, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Roper washing machine agitates but will not drain or spin
its your lid switch. it cant spin til that switch is closed,and they break all the time.its thru that hole where the lid seats on the top of the washer.also some times the switch actuator on the lid breaks,but not as offten.inspect that area and you will see issue.you can cut and connect the wires underthere in a pinch[there are three wires to the lid switch.dont connect the green ground its the other two]but you must be careful if you have children they will be curious and lift the lid and it wont stop spinning,so if they reach in with there arm,their has been cases of arms being torn of from spinning tub.how this helps God bless ,tom
Jan 26, 2009 | Washing Machines
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore agitates doenst spin
blaker, check the lid switch, no spin, no drain, usually a broken lid switch...Catriver...post back.
Sep 15, 2006 | Kenmore 23012 Top Load Washer
Whirlpool LXR6432JQ Top Load Washer Logo
47 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
