Question about Lexmark T642 Laser Printer
Message on screen reads: 920.26 Service Fuser Error. I've tried switching it on/off, still won't work and none of the buttons will cause the error message to dissapear.
  • 2,296 Answers
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T642, the manual states you should power off the printer and power it back on, which you did, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 17, 2011
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
May 23, 2017 | Acer Aspire One Netbook
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
I have an hp 4300 with a 13.12.00 error when the duplexer is installed
Here is a copy of the 13.12 error troubleshooting steps from the service manual.
1. Press the HELP ( ) button for
detailed information about
clearing the jam.
2. Press the UP ARROW( )
button and the
DOWN ARROW ( ) button to
step through the instructions.
3. Check the paper width and
fuser delivery sensors
(PS106, PS108) and verify
that the sensor arms move
freely. (See "Location of
printer switches and sensors"
on page 336.)
4. Check the inside of the
duplexer for scraps of media
that might have torn off when
a jam was cleared.
5. Replace the media-size
sensor (PS106) and fuser.
See "Location of printer
switches and sensors" on
page 336 and "Fuser" on
page 162.
6. Turn the power off. Remove
the duplexer and turn the
power on. If the error
message persists, replace
the DC controller PCA. See
"DC controller PCA" on
page 181.
7. Replace the fuser (PS108).
See "Fuser" on page 162.
8. If the error message appears
frequently, see "Paper-path
troubleshooting" on
page 295.
Feb 07, 2013 | HP LaserJet 2420 Printer
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Our copier reads an error message of SC541
this problem can be solved by pressing the yellow button,then enter 107 and hold down the red button till the screen changes to copy SP,press OK or 1.The macine will now be in service mode.switch the machine off then on again.if it go into SC541 again the problem lies with the thermistor of the fuser unit
Mar 07, 2011 | Savin Office Equipment & Supplies
Sir, I have on the machine power many times. But all time it screen had been shown an error "SC546" and some instruction below the error is this "switch try on/off" and call service. I...
That is caused by either a dirty or defective fuser thermistor.
What you can try is this.
Press the yellow clear all button, then 107 then hold the red stop button until the machine switches to SP Mode. Then press the copy SP or system SP button. When that page changes, shut the machine off then back on. If the problem comes back you will have to remove the fuser and clean, or replace the thermistors that make contact with the hot roll. That is the black aluminium roll in the fuser unit.
Nov 12, 2010 | Gestetner Copier
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Lexmark T642 Laser Printer Logo
1,315 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
