Restart your computer during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup (BIOS) this will differ depanding on you computer and operating system bios
You have different keys to click on different PC. Since you have not specified the kind of laptop you have, here are few keys you have to strike: Turn off computer first then before it opens, you have to click DELETE key randomly to enter to bios utility setup. If it does not work, turn off again and try F12, if it doesn't turn off then try these: F1, F11 and ESC. Congratulations.
Don,t do that insatead: Entering the BIOS Setup menu
Entering
the BIOS Setup menu requires pressing a specific key at a specific
time. If you fail to enter the Setup menu on your first try, repeat the
following steps until you are successful:
Close all applications that are currently running and restart the computer by clicking Start
, Shut Down
, Restart the Computer
, and then OK
When the red Compaq logo or blue HP logo screen appears, press the F10
key on the keyboard to enter the Setup menu.
NOTE:
An
alternate to the above steps, especially if the logo screen disappears
too quickly to enter BIOS, is to shut down (turn off) the computer. Wait
30 seconds, turn the power on and press F10
or F1
at the logo screen.Reloading the default settings
Complete the following steps to reload the factory installed BIOS Setup settings:
In the BIOS Setup utility, select the Exit
tab.
Select Load Setup Defaults
Select Save Changes and Exit
(pressing F5
and the Enter
key will also load the Setup Defaults).
Try resetting the BIOS in case something happened to it.
Power down your computer. Remove the power cord, the rechargeable battery and the BIOS battery. Wait 10 minutes. Reinstall the BIOS battery, the rechargeable battery and the powewr cord. Restart your computer and enter the BIOS setup.
If nothing happens, your video card may have failed.
If not, reset the mobo: either remove the mobo battery for a few minutes, or "short-out" the two reset pins next to the battery or next to the CMOS BIOS chip.
If you are not using the built-in video interface, then put two monitors on the system and adjust the way you want the monitors to behave.... or disable the built-in vga interface through the BIOS setup.
System was configured to run at a higher-than-rated speed. Just press the delete key when instructed to enter BIOS setup. It will probably reset to its default timing arrangements. Then press F10 to save the settings and exit the BIOS setup.
The MacBook systems use Intel's Extensible Firmware Interface (EFI) rather than the traditional Macintosh ROM or PC BIOS. So, no such thing as going into the BIOS for advanced setup on Intel Macs (like you can on a PC).
The keyboard and touch-pad are connected to an internal USB interface, If no USB interfaces are working at all this suggests that the USB host controller (a physical computer chip) has failed.
You can try a chip-set reset; disconnect both power and battery and hold down the power button for 30 seconds (timed), this will reset all chip settings to default and discharge any static buildup but this is in no way guaranteed to fix the problem.
If the laptop is still under warranty arrange for repair.
In the mean time most of the Aspire 5100 series have a PC card slot on the side so you could use a USB or PS2 host card to connect a keyboard and mouse.
