Question about Advent Netbook
My notebook will not switch on even when plugged into the mains although I think that the mains feed is a bit dodgy too. It worked perfectly last night before I switched it off and plugged it in to recharge. Ann
  • 540 Answers
Hi!
Please remove the battery and power cord from the laptop then wait for 60 secs. and connect the power cord only and try to power on if the laptop do not power on then either dc jack or the power circuit board is defective.
Posted on Aug 22, 2010
JVC kd-r332 settings keep resetting after unit is turned off
I had this exact same problem - in my case caused by the wire that should provide a continuous feed so the unit can keep its settings actually being from the ignition switch, and the continuous feed wire being connected to the terminal that should be from the ignition switch! I had a red wire (continuous feed) and a yellow wire (ignition activated feed) feeding to the back of the unit, and all I did was to switch these over - both wires had their own connectors let into the wires a few inches from the unit so that switch over job was easy. Works as it should now, although i have a grazed knuckle as the wires leading to the plug at the back were a bit too short! Chris
Jan 09, 2013 | JVC Kd-r332 Cd Mp3 Car Stereo, Dual Aux-in...
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Windows fogging up in a pt cruiser
The "mechanic" misconnected something
Jul 18, 2017 | 2003 Chrysler PT Cruiser
Battery test shows that it is fully charged, but
There is a possibility that the battery has a damaged or faulty surge protector. This will make the battery work at random times. This is not a fixable issue outside of replacing the battery again.
Return the battery and get them to send you another if possible.
Feb 12, 2010 | Dell Inspiron E1505 Notebook
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
Washing Machine will not turn on
Check the fuse braker (box out side) The lid switch may be stuck with soap and etc stopping the plunger from operating properly. Lid and door switches stuck, see if not pushed in and release out when lid or door opens. Hope this may help you.
Jun 02, 2009 | Washing Machines
Will not charge although it can detect it is plugged in
Hi Natasha,
Unfortunately this is a common problem with current Dell laptops. The notebook checks whether or not you are using an official Dell charger, and if not then it refuses to charge the battery even though the laptop will still work. This means that if you are using a third party charger you will only be able to keep doing what you are doing.
If on the other hand it IS an official Dell adaptor then it is possible that the sensor in the adaptor is faulty. Either way if you want your battery to charge you will need to get the right adaptor from Dell.
I don't like the fact that Dell notebook work this way as there are many perfectly good third party adaptors on the market but at the moment there is no other way around this issue.
All the best
Rob
May 27, 2009 | Dell Inspiron 1525 Laptop
Have forfd focus 1.6 ztech 2006. Boot release keep coming in it self. Any idea. Any feed back would be welcome
hi there i think it will be a dodgy switch next to gear stick its a push button change that
Dec 14, 2008 | Ford Focus Cars & Trucks
Doesn't turn on!
I had a "Doh!" moment the day after posting my problem. As I was packing up the scanner to put it in the attic, I suddenly noticed the on/off switch on the side. I'd never noticed it before. Connecting everything and flicking it to ON made the lights come on and my scanner worked perfectly. I'd recommend switching off at the mains after every use, however, as there is something a bit dodgy about the power supplies.
Aug 20, 2007 | Canon CanoScan 8400F Flatbed Scanner
Advent Netbook Logo
78 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
