Question about LG Dryers
My lg dryer unit is not starting even thou it has power.
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 22, 2010
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
My LG steam dryer is stuck on pause. I've tried unplugging it and re starting. I've tried the other buttons. Nothing works. Help!
Possible that the processor in the main controller unit has hung up. If there is no result even after the power plug is removed for few hours or even overnight, it is possible that the controller unit has failed.
need to confirm if you able to source one for a test before you order or invest.
Oct 18, 2011 | LG Dryers
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | LG DLG5988 Gas Dryer
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
I bought a LG DLEX2501 today. I am frustrated as
check your main power supply and make sure there is enough power to the unit.you could have a problem with the main control board. if this dryer is new the best thing to do is call a service company out and have them look at it
Mar 05, 2010 | LG DLEX2501 Dryer
LG DLE5977 electric dryer, 3 years old. On power up: check filter display is lit. When cycle selction is made and start button is pressed, unit begins to heat, but dryer drum will not turn. Unit hums. I...
Your belt is likely broken. I am presuming you DO NOT have a setting on your machine that allows the drum to not turn or if yours does have such a setting you have not selected it!!!
I am not intimately familiar with your particular LG model even though FixYa.com rates me a LG expert.
Dryer tops are generally held in place with spring clips. Pop the top being careful to not mar the finish. Look for the belt (about 3/8 inch or so wide). The belt will be near the middle of the drum. Try to pick it up. If it is broken, you will be able to remove it. If it has slack in it but you can't remove it, it is probably off the motor pulley. Put it around the pulley through the belt tensioner.
Remove the front - use care you don't damage any wires.
The drum will fall free at this point. Take pictures with your cell phone to aid in reassembly.
You can get replacement belts from a FixYa.com advertiser, your local appliance parts place or visit www.repairclinic.com
Thanks for using FixYa.com
Please vote
positive comments appreciated
thanks
a
Oct 29, 2009 | LG DLE5977 Electric Dryer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Nov 14, 2008 | Fisher DEIX2 Dryer
My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Mar 15, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
169 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
