Question about Kitchen Appliances - Others
The toaster doesnt work, light doesnt turn on. Have opened the toaster, but cannot see what is wrong with it. It is just over 2 years old.
  • 2 more comments
  • hronnvr Aug 22, 2010
    It is a KitchenAid KTT780 2Slice Toaster.
    "find the contact that is touched when the toaster lever is pressed down" - this is a KitchenAid KPTT780. Do you have a solution that fits my toaster????
    Thank you.
  • hronnvr Aug 23, 2010
    Thank you caroldon for this answer. I have been checking the internet and apparently I am not the only one having this problem with the KitchenAid KTT780. Just shortly after we received the toaster the peep that is supposed to let us know that the toaster is ready, stopped working. Then the switch only worked sometimes (there comes a blue light that indicates that the toaster is on), then it just stopped working. Does this sound like a more switch problem or??? And have you received many requests regarding this type of Kitchen Aid??
    Thank you jayantjha355 for your answer. Have you read my comment that I posted earlier.
    "I have been checking the internet and apparently I am not the only one having this problem with the KitchenAid KTT780. Just shortly after we received the toaster the peep that is supposed to let us know that the toaster is ready, stopped working. Then the switch only worked sometimes (there comes a blue light that indicates that the toaster is on), then it just stopped working. Does this sound like a more switch problem or??? And have you received many requests regarding this type of Kitchen Aid??"
    Please don't give a standard answer, I need a tailor made solution to my problem.
    Thank you.
    Genius:
  • 1,622 Answers
You can fix this yourself by taking the following instruction below,
Check on the power plug of the toaster, if it is okay or firm to the power socket source, if otherwise open the toaster, check if there is blown fuse, if it is replaced with the same rating, but if otherwise check the thermostat and the element of the toaster by using a multimeter or a digital meter to read the two component, this must read a continuity in the ohms ranges, if otherwise it is bad replaced to a new one of the same rating. Thanks for using fixya , take care
Posted on Aug 23, 2010
  • 857 Answers
Toasters are categorized as heating appliances. Their function is to develop sufficient heat near a slice of bread to heat and toast it. Breakfast certainly wouldn't be the same without the pop-up toaster.
In many homes, toasters malfunction more than any other small appliance. There are two reasons for this. First, toasters are typically built economically to be a throw-away appliance. Replacement models start at $10.
Second, malfunctions are frequently not the fault of the toaster itself but of food particles that interfere with its operation. Excess pieces of bread broken off by carriage movement fall into the base of the toaster and accumulate, obstructing carriage movement, shorting out heating elements, plugging the latch release, and interfering with solenoid operation
That's why most pop-up toasters have a large crumb tray and door at the bottom of the toaster. By sliding or unlatching this crumb door you can release food particles trapped in the bottom of the toaster.
For a toaster that is used daily, this should be done once
a week. Simply unplug the toaster, hold it over a trash
container, and unlatch the door. Once the primary food particles have fallen out, move the toaster around to release other particles that may be trapped at the edges. Periodically clean out the toaster using a can of compressed air, making sure you don't damage sensitive heating elements or switches.
  • 17,129 Answers
There is the heating coil which mustt be checked primarily to be showing a good ccontinutiy. Use a good multimeter and check the continuity of the heating coils, then check on the switch, remove the power off when you are doing this test.
Now check the line continuity of the plug , main wires to the switch. If open connection change the main wire /plug with a sealed with the same rating.
If line is OK, the the fault will be with the switch but if the heating coils are bad, then I think it might not be economical to replace than to buy a new one. So check and decide with your inferences.
    Genius:
  • 1,456 Answers
Hi there!!
Unplug the toaster before you work on it.
Make sure the toaster is getting power if it won't work. Is the cord intact? If the cord seems OK, check the actuator ' open up the toaster and find the contact that is touched when the toaster lever is pressed down. This metal part may be bent. Reposition it with needle-nose pliers.
Check the trip rod if crumbs aren't the problem. This small rod is attached to a bi-metal strip that heats with the toaster. As one type of metal heats faster than the other, the strip bends and pulls the rod away from the carriage, eventually releasing it. The rod may have slipped out of its hole.
Posted on Aug 22, 2010
I have Sunbeam 'Radiant Contol' TOASTERMATIC toaster. Must be 40 years old - and only recently stopped toasting. Is there anyone who might fix this - I think the radiant coils have burnt out. I live in...
There could a number of reasons why it has stopped working and depending on the problem it could be a simple fix but generally not. It is after all an old toaster as you realise. On the bottom is a model number AT-35 AT-40 or TA-J. It depends on what part is sentimental as the outside and ends and base can be transferred over to a working mechanism. I have a few of these toasters and think they are just great.
Sep 08, 2010 | Vacuums
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
Not toasting at all. Worked on 4 slices the nothing,
Rotate the dial all the way one then the other a few times. Maybe something behing it. It this is helpful, please post as such.
Jan 10, 2009 | Dualit CTS4E 4-Slice Toaster
Toaster burns everything
It sounds like the heating sensor is longer functioning and the toaster is probably kaput, unless you can find an independent repairman who works on small appliances. In my own experience even a pricey toaster last about 3-5 years. I had the same problem with the same brand, just a different style
Aug 15, 2008 | Cuisinart CPT-160 Metal Classic 2-Slice...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
Kitchen Appliances - Others Logo
218 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
