My KENMORE Heavy Duty,Dual Action washing machine does it have a fuse inside? Washer does not start, it is now full of water and I cannot find the model # as it is too heavy to move. Thank you!
    Champion:
  • 245 Answers
Check your lid switch. It is located in the little oval hole on the right side when you open the door. The model # is locted right in front of you when you open the door. Very common problem. Rate me if I helped you.
Posted on Aug 22, 2010
Testimonial: "Thank you Lancaster 5. Very useful suggestions! Will follow them, Jacob"
Water does not drain from washing ma
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the washer will spin it sounds as if the pump / hoses are blocked or the pump is damaged.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
Mar 14, 2010 | Kenmore 24032\24036 Top Load Washer
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
I have a top loading Kenmore Washing machine, Model 110, Heavy Duty, dual action. The machine is level but during the spin/unload cycle, the machine bounces around and makes noise. If I put two cases of...
There are pads on the tripod and skid plate that wear out and can be replaced. There is fluid in the tub ring that may have leaked out. The base (tripod) can be bent and cause vibration problems. The flooring material and support can cause this also. I would start with the floor and work up through and eliminate the causes to find the culprit.
Eric
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
