Question about Microwave Ovens
Tried to turn on oven to highest setting and it began beeping and had an error number F-5 showing.
  • Microwave Ovens Master
  • 9,098 Answers
Please contact us with the full model number so we can help you further.
Posted on Aug 22, 2010
Jmc8100 built in over jmw8530cas. only button on touchpad that works is stop/clear. turn breaker off for 12 hours, can set clock, use once or twice come back in 5 minutes, and only stop/clear beeps. have...
You have a failing membrane keypad.
On some models, you have to replaced the keypad separately.
I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you can replace the whole control panel frame, which comes with a new keypad already installed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also get details there if you need more help with the repair.
Oct 15, 2011 | Jenn-Air JMC8100 Microwave Oven
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
How do i fix an f30 error code on my frigidaire range? it only beeps when i try to turn on my oven... and shows f30
Sorry to read about your problem, I hope this helps you out.
You have a shorted keypad membrane.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Microwave Ovens
I'm getting error 40 on wolf warming drawer, with beeping...buttons don't work...rest breaker few times...doesnt work...
Not knowing the make and model number of the microwave doesn't give me much information to work with. Try to google the make and model number, along with the phrase "unit beeps and error 40 on warming drawer", and see if something comes up. There are sites with error codes, which might help.
Also, refer to any literature that came with the unit, to see if they have the error codes listed, and what they refer to.
You can often go to the manufacturer's site and find useful information about various problems, and what needs to be done.
Wish I could be more specific, but will try to check back to see if you can include the make and model number, and then we will go from there.
Oct 31, 2010 | Microwave Ovens
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
Microwave is beeping even though everything has been cancelled. We already tried unplugging to reset....still beeps.
Chances are you have a shorting membrane keypad. It's very common.
Ever had the F3 error?
Sep 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Getting error code F-3, microwave beeps with this code, entering Clock, then the time clears the code, then can use microwave, but after sitting code comes back on. Have tried unplugging oven for several...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad. It can be intermittent.
On some models, the keypad can be replaced as a separate part.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
But on some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
JVM1490 IS BEEPING EVERY 4-5 MIN ONE BEEP
The manual states that it will beep once a minute after food cooks until you open the door or press stop. Other than that, it sounds like an error condition. But you might contact the GE Answer Center at 1-800-626-2005 Monday 6 a.m. ET through Saturday midnight ET. The owner's manual is available here: http://www.geappliances.com/service_and_support/literature/
Mar 15, 2007 | GE JVM1490 Convection/Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
