Question about Insignia 42" LCD Flat-Panel HDTV
How do I get my Insignia 42" to show movies from my PC using an S-video cable?
    Scholar:
  • 122 Answers
Make sure your S-Video is hooked up.
Now navigate your way to the Display options.
Now either extend your monitor to fit your TV or move the primary display to the TV. Also make sure your input on your TV is set to S-video.
That should move your display settings to your TV. Also do the same thing for your sound if your computer still plays the sound.
Just go to your sound options and make sure your TV S-video is set to default sound and it should chance from your computer to your TV.
Posted on Aug 22, 2010
How do i connect the pc to the lg tv to watch a movie
Hello......Let's talk video....Your Tv has an S-video input and a VGA input....Chances are your computer's video card hay not have S-video output...It's small ,round...looks similar to a PS2 mouse or keyboard port.If it does...you can use the S-video(SuperVideo).If you computer is not equipped with this...You can use the VGA typacally used to connect the monitor to the pc...Depending how far apart the TV and the PC are..this can be easy...this determines the length of the cables you are to use...If you go with the S-video cable..It may be less expensive...if you go with the VGA cable..be sure to get one long enough...as far as the sound...since your tv has a VGA input...I may also have the sound input for your pc connection..This requires a cable with a 1/8" stereo plug on either end...You can connect one end to you tv and the other to the headphone jack on your pc....or you could just listen to the sound thru the pc fpr now....Let me know how this works out....I hope this was helpful....PEACE....
Jan 26, 2012 | LG 42PG20 42 in. Plasma HDTV
I hooked up a Sony dbl side DVD burner to my Insignia D400 and I am having problems with the video whenever I try to record a music show or concert. The speed of the video is faster than the music. It...
Your best bet is to add more RAM. You need more than 512mb for video encoding and recording. The more the better! A really good site for finding out what you need is www.crucial.com
May 05, 2011 | Insignia D400a PC Desktop
SLOW MOUSE TRACKING PROBLEM & VIDEO/AUDIO SYNC PROBLEM with 27" iMac Quad computer. Using 42" Insignia as a second monitor using HDMI DVI cable. The video card unable to serve both monitors' draw...
I am using my tv as a second monitor as well, and i believe the lag problems with the monitor are due to the video/graphics card. I am not expert, but my pc is an alienware aurora with quad processors and 6gigs of ram. The only thing not top of the line is my video card, plus it gets slightly pixelated due to resolution not being sufficient from my video card. Otherwise flight sim X runs smoothly, except for the mouse lag issue. Best of luck, if your program is lagging also though, might be your driver
Sep 08, 2010 | Insignia 42" LCD Flat-Panel HDTV
Anytime i watch a premium channel, on demand movie the image is blurry and jumpy to the point of getting a headache. Regular HDTV seems to be great with the exception of the blacks on occasion, popping to...
It the tv,it have intermittent video problems,with the Tuner board.That the board in the tv,where the cable company broscating signal cable plug into it.U used a HDMI cable to plug into HDMI port hub to get ur HD signal.Take it back talk to Best Buy,tell them this tv have intermittently not supporting HD frequencies changes.Tell them upgrade the tv frameware software for u
.Or keep presisting give u another replacement tv.
Aug 02, 2010 | Insignia 42" LCD Flat-Panel HDTV
I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
Nov 30, 2009 | Insignia 42" Flat-Panel Plasma HDTV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
I am trying to usa a VGA cable to watch my mac book pro on my 42" Insignia 1080P hdtv. when I do I just keep getting the message not supported on teh TV... I have changed my screen ratio on my mac book pro...
Use a 60Hz refresh rate and a basic resolution (Like 1024x768), is it works, set the resolution to the native of the display (Maybe 1920x1080 @ 60Hz).
DON'T set a refresh rate higher than 60Hz for any LCD.
Oct 27, 2009 | Insignia 42" LCD Flat-Panel HDTV
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
Insignia 42" LCD Flat-Panel HDTV Logo
73 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
