Question about Vacuums
Can I use a regular 2 conductor cord set on a ceiling track lighting kit and plug it into the wall? I Dont have a box in the ceiling
  • 490 Answers
Yes, but make sure to use a polarized male plug ( the one with the slightly larger prong on one side).
Posted on Aug 22, 2010
Testimonial: "Thank you "
  • 1 more comment
  • dag_king Aug 22, 2010
    Does it matter witch one I connect to the black conductor?
    By the way thank you for you help
    ok ,so the ribbed side connects with white
    and the other to black?
    does it need to be grounded, meaning using the green wire?
Why is there only 1 conductor in the power cord?
You always need 2 leads one for the return, power require always a difernce of potential to produce a circuit
Aug 03, 2014 | Blue Wave NE3855 Nitro Wall...
Blue light flashing on shark steam and spray mop
Read manual under trouble shooting.
1. If you have already plugged in the power cord, unplug and re-plug into another electrical wall
outlet. This may reset the Standby mode.
2. Add water to the water tank and press the On/Standby button to select a steam setting.
3. If your unit still does not work, call Customer Service at 1-800-798-7398.
May 27, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to repair
A wire might have come loose inside the Vacuum head.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
Remove/Dismantle the Vacuum head and locate the wires.
Check the wires at the terminals and at pinch points
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 08, 2014 | Hoover S3670 WindTunnel Bagged Canister...
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
Hoover wiring
hello lukeplayer,
Based on your description, ( first disconnect the plug from the wall recptacle).You will need to open up the Hoover Vacuum Body to gaion access to the internal wiring. In order to better assist you, please provide me with the specific hoover model. In general though, you will need to see where inside the Hoover that wire became detached and then rerun it. Since your cord is already broken, you may be able to strip back more of the outer cord insulation to expose the internal conductors and then route, cut to fit and reinstall them. Hope that helps.. If not, send model details,,,
Regards,
Rick
Nov 26, 2008 | Hoover Vacuums
I have a Hoover Windtunnel 2 upright vvacum cleaner. During regular use my wife turned it on and it staarted cleaning, then all of a sudden it stopped and then started again then stopped for good. I...
It sounds to me like the power cord has a short. To test your power cord you need a multimeter. Test continuity threw the power cord, from the male plug prongs, to the wiring inside the vacuum. You should get continuity from one prong on the male plug to only one wire on the other end of the power cord. If you test one prong but get a readying on 2 wires, then it is crossed. If you dont get any continuity on one or more of the wires, you have a short. A common place for a short in the cord is the male plug, you can find a replacement male plug at a hardware store and cut off the old one. When wiring the male plug, black wire goes to the gold post, white wire goes to silver, and green wire goes to the green post.
If your carbon brushes on the motor are warn, then that could cause the motor to stop, but other parts of the vacuum should still work so I dont think it is that.
Hope this helps.
Jun 27, 2008 | Vacuums
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
