Question about Continental CE-AC75271 Ductless Mini Split System Air Conditioner
P1 error on mobile 12,000 BTU continental AC. Unit say 8.8 when you try to make it start and then go to P1 error
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
It will not say on unit what the kbtu is?
There is 12,000 Btu of cooling per ton. 5 tons = 60,000 BTU
Sep 07, 2013 | Carrier 5 Ton Infinity High Efficiency...
Installed a 12,000 btu LG window unit. Did not see that the plug was a standard 250v. I changed recepticle, and the manual said to be sure to have a 20 amp breaker, which there is. The unit comes on but...
What is the voltage of the unit? What is the voltage of the circuit? You say standard 250 V plug ... is that the rating or the configuration of the plug?
More specifically, your 12,000 BTU unit should be on a circuit of its very own to preclude over loading the circuit and causing damage to your AC.
Aug 05, 2011 | Heating & Cooling
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
I have a Ruud AC model UACC-056jas serial number 3170 F1085 5657. Does anyone know the tonnage?
That would be a nominal 5 ton BTU unit or 56,000 btu....
At 12,000 btu/ton you can see that it is just a bit short of 5 ton but larger then 4 ton....actually about 4.75 ton....
heatman101
Apr 12, 2011 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
Continental CE-AC75271 Ductless Mini Split System Air Conditioner Logo
78 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Tim Whalen
Jay Finke
Jay Finke
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
