Question about Dynex 5-in-1 USB 2.0 Mini Memory Card Reader
How do you insert the memory card into the reader? I am afraid to just shove it in. I have a Sony MemoryStickPRODuo.
    Brigadier General:
  • 10,406 Answers
One corner of the memory-card is "bevelled", to prevent it from being _wrongly_ inserted, i.e., if it does not go "far" into the slot, then flip it over, and push it in until you feel "resistance".
Posted on Aug 22, 2010
How can i recover the pictures in my SD pro duo memory card which when inserted in my Sony DSC W330 it appears reinsert the memory card which infact it is already inserted? pls help me.,what should i do?
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software from
hope this helps.
Aug 09, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony Memory Stick PRO Duo Not reading
Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
Feb 13, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Sony 512mb Memory card
You can insert the memory card to the card reader and then insert the card reader to the PC. Access the drive where the memory card created and then right click it and then format.
You can format also using the menu of the camera. refer to user manual in formatting camera storage disk.(memory card)
may this help:
melnavz
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Dynex 5-in-1 USB 2.0 Mini Memory Card Reader Logo
162 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
