Question about Refrigerators
Kenmore cold spot model #106.55522400 ice maker not filling with water. water comes out of door fine.
4 Suggested Answers
ghappliances
  • 126 Answers
SOURCE: kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Posted on Sep 10, 2008
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Ice Maker does not work.
Check the line going to the ice maker for clogging.
Sep 25, 2009 | Kenmore 57029 Side by Side Refrigerator
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
