Question about Miele Novotronic Premier 500 Front Load Washer
Leak have a Miele Washing machine (premier Novo) which I have had for a number of years, and when I switch the machine on, I get water comming out of the bottom LHS filer trap unit!!! can any one help? I've checked the top unit and removed and cleaned out the conditioner unit, I have also unscrewed the filter thing in the lower LHS dront oof the machine behind the flap, and seen what looks like a "Y" type of plastic which rotates freely and has 5mm movement back and forth.. can anyone help???
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Mielepremier novo. No power though plug fuse OK. Door won't open.
I had the same problem with a Miele W828. I removed and reinserted what I think was a condensor where the power cord is attached, after which it was OK. I assumed that it was loose but might have just been lucky in bumping something else back in place when I tipped it onto its side.
Mar 28, 2009 | Miele Novotronic Premier 500 Front Load...
Leak from tap at front of machine
the filter may not be sitting right in its slot - an obstacle may be keeping the filter from being seated all the way - once the filter is fully seated, it blocks the water to the front tap
Oct 27, 2008 | Miele Novotronic Premier 500 Front Load...
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Feb 17, 2008 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
419 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
