Question about Amana ACB087R Air Conditioner
The read out says E1 and the unit doesn't work
  • Amana Master
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Posted on Aug 22, 2010
Channel Master Digital Analog Converter Box CM-7000
E1 is a 100 uF 16 VDC capacitor. I have been repairing these units lately and have experienced some of the same symptoms (LED goes red but doesn't transition to green after 30 seconds like it should). I have been able to repair some of these units. Make sure the power supply is working properly before spending significant time on the D2A board. The power supply is responsible for supplying 12, 5, and 3.3 VDC to the D2A board. A defective PS will measure 14.5 instead of 12, 6 instead of 5, and 2.9 instead of 3.3. The AC ripple should be about 5 mV on the 3.3 and the 5 volt supplies when loaded. The 12 volt can be as high as 50 mV on a good PS. The culprits are C12 (1000uf) and C10 (470 uf) which are the filter capacitors for the 3.3 and 5V outputs respectively. C12, the capacitor for the 3.3 V output is especially critical because it is used to feed the voltage regulator and overvoltage shutdown circuit. D7 is a hot part and can also fail sometimes. I have repaired 50% of my units just by changing these capacitors. I still have units where the D2A board is bad with a known good power supply. If anyone has more info on the D2A (like a schematic) please pass it along
Feb 25, 2012 | Televison & Video
I did install all correctly, but i turn it on and like 3-4 min it turns off and indicates an E1 on the display!! Whats wrong?
To help you. I will need to know what Brand your AC unit is and the Correct Model Number. The E1 error code doesn't mean the same thing on all brands and models.
Thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
MY WINDOW UNIT JUST STOPPED WORKING AND NOW IT IS READING E1. HOW DO I GET IT TO WORK AGAIN?
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
TOC reading... e1 error
Buy a cd cleaner kit, if it doesn't work have some one capable re-align you laser len. When the unit get use for times the len got tired(worn and mis-align). Goodluck.
Mar 06, 2008 | Panasonic CQ-VD7001U Car DVD Player
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
It may be a timer setting after a power problem. On page 90 of the manual there are setups for the timers My VCR won't do things without the time set either. The manual may be downloaded here.
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Basically get into the setups and set the time and hit enter. I hope this works.
Sep 12, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Unit stops working - E1
I wrote the solution #1 and have an additional comment. This really does work!! I fixed my neighbor's AC unit by following the instructions for clearing the E1 code. The unit will not operate until the code is cleared. The page is titled: Customer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners
Aug 25, 2007 | Sharp AF-S80FX Air Conditioner
Haier E!
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
Aug 08, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
F2:E1
This has happens to us regularly. Today when it happened I unplugged the oven and let the it cool hoping that would help. It didn't. I did that several times over a couple of hours to no avail. When it powers up, there are a sequence of different readings on the screen before the error code comes up. In my final effort, just before the code F2:E1 appeared, and it read PF, I quickly turned on the oven and that interrupted the sequence. It is now working. Lucky. I hope this helps someone.
Apr 03, 2007 | KitchenAid KGRC707 Stainless Steel Gas...
Amana ACB087R Air Conditioner Logo
400 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
