Question about Razor E100 Electric Scooter
Got the scooter for xmas last year -- has been used approximately 5 times. SHows battery is fully charged. Will not go. Need help.
    Problem Solver:
  • 10 Answers
Hello,,i'm not overly familiar with these but,,here goes,,,,if it is reading fully charged,,but it will not go,,,,if you have an electrical tester,,,plug the red probe into the red wire connector on the battery,,,,and the black one to the black connector on battery,,,,,just to be sure charge gauge is reading correctly,,,,,,if it is indeed fully charged,,,,now go to where you engage the power,,,,whether it be a pedal,,or a trigger on the handle bar,,,,,you will have to check all connections to be sure one has not come off,,,,or got to lose to make a connection,,,,if all looks ok there,,,,check the wires that go to the motor ,,, from the battery,,,,make sure all is secure,,,,, if it has gotten wet,,,check for any corrosion on all your electricals,,,,,,and clean ,,,,,when your doing all this,,,,,also check for a broken wire,,,,,or stripped wire,,,, hopefully these steps will put you in the right direction and back to riding,,,,, JOEL
Posted on Aug 22, 2010
HI Scooter is on charge full time and used daily after 30min i loose the first green light that is OK but if i dont use it for one or two days i loose the first green light only after 10min can you...
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
May 12, 2011 | Invacare Supply Group Invacare Scooter...
How does the charge indicator work-- after the charger light has gone to a steady green light when ~I disconnect and switch on the indicater shows an almost continuous red line across the display
You are fully charged. As you use up your charge the red line will get smaller from right to left and when you get down to 2-3 lights you need to recharge. If you use your scooter daily then recharge every night plug in when you goto bed unplug in the morning and you are good to go. if you do this the batteries should last ya 2-3 years. Hope this helps
Apr 16, 2011 | Health & Beauty
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
When I plug in the charger is shows green, but the scooter does not run. Should I replace the battery or the charger? E100 razor.
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Mar 28, 2010 | Razor E100 Electric Scooter
My scooter says its fully chrged but its not. this happens once in awhile, any suggestions?
your batters have lost their charge at some point in time. These gel batteries, if they ever set for a long time with out recharging, or arn't recharged daily with daily use, will seem to be charged. but arn't. their expensive but I've seen batteries last over 5 yrs when taken care of properly.
Nov 09, 2009 | Pride Mobility Victory 3 Wheel Electric...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
My go go elite Scooter will not work. its only just over a year old. it's not been used for a few months. When put on charge the charger shows its fully charged. When the scooter is swithched on the volt...
It may still be under warranty.  What kind of reading did you get from the batteries? If they are below 12.0 volts they may have a poor memory. If you leave a chair un-charged for a long period of time the batteries can discharge to a very low level. The charger cannot bring a battery up from 11 voltsDC. You will need a slow car type charger or new batteries.
Mar 19, 2009 | Pride Mobility Products Go-Go Elite...
New 55ah batteries but charge won't last.
Battery life is affected by many things. But inside a tiled space like Walmart is probably the best possible running conditions. Make sure your tires are fully inflated, and you may need to have the motors check for worn brushes or maybe the wheel bearings are dry. Does the scooter push hard when in free-wheel mode? You may also need to have your charger checked, to be sure your batteries are really being fully charged.
Nov 22, 2008 | Pride Maxima 4-Wheel 4-Wheel Scooter
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
Razor E100 Electric Scooter Logo
310 people viewed this question
Top Razor Toys Experts
Clif Roberts
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
