Question about Bosch Nexxt 300 Series WFMC2201UC
When I try to wash I get a E27 on the display
  • 3 Answers
I had to call the repairman. He said it was an overheated solenoid in the door lock. The "repair" is to let the washer cool for about 10 minutes (unplug it), then try again. If you're still getting the code, you'll probably need to call a repairman like I did. Though once he put it into diagnostic mode the code "cleared" and it works again. The final fix is to replace the lock.
Posted on Sep 29, 2010
  • csmith59 Jan 01, 2011
    I am having the same problem with a washer that I have had just a little more than 30 days. I am curious if your washer was new or several years old?
How to clear error code e27 on bosch vision 300 washer
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
Feb 08, 2016 | Bosch Vision 300 Series 3.3 cu. ft....
What does error e27 indicate?
try going to google and enter the make,the model # and the error code and you will get many answers
Nov 01, 2015 | Washing Machines
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
Installed new door lock still have e27 error code
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You can manually release the latch by removing the lower panel (Torx fasteners, I think) and finding a wire lanyard that releases the latch. However, I had read that there was a diagnostic code that could be used to reset the latch solenoid via the control panel.
There is no service manual available on line, as far as I can tell.
Here is what worked...
Oct 15, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Washer says e27 have replaced lock set will not clear
E27 means you have a problem with the door lock . It could be the door is not shut all the way or the lock assembly is just bad and needs to be replaced. If you have turned the unit off and back on from the power supply I would say you probably need to replace the door lock.
It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If this doesn't remedy the error code, you'll need to schedule a service call.
Hope helps.
Sep 22, 2011 | Bosch Washing Machines
Error message E27 appears and washer won't operate.
E27 means there is a problem with the door lock. Unplug the machine for 5 minutes and try again. If the error code returns you will need to replace the door lock assembly.
If you have anymore questions please comment me back.
Jul 28, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Mar 10, 2011 | Bosch Washing Machines
Just got a brand new Bosch series 500 DLX and it is giving me E12 and E27 errors.
Just fixed the E27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal.
Oct 14, 2010 | Bosch Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
885 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
