Question about Whirlpool Dryers
Dryer wouldn't work last week. Found the Thermal Fuse with no continuity and replaced it. After drying one load of clothes yesterday, dryer won't work again. I suspect the thermal fuse again. What else (thermostats??) and how do I check? Dryer vent is okay.
    Champion:
  • 245 Answers
Or your breaker. The dryer will work just won't heat with the thermal cutoffs or element or the breaker. Dryer won't do anything if the thermal fuse is bad. You might also want to check the outlet from L1 to N and L2 to N for 110 on each side. Good luck.
Posted on Aug 22, 2010
About two weeks ago, my Kenmore 600 dryer which by the way is only 1 yr old, wasn't heating to dry the clothes, we discovered there was blown fuse, so we changed it and it worked fine until yesterday, it...
could be the thermal fuse it is usualy white about 1 in long located in the rear of the dryer at the bottom around the exaust fan if no continuity it is bad
Jan 06, 2011 | Dryers
1 week ago the dry was extremely hot and now this week the dryer is cold and the clothes are wet.
Last week your cycling thermostat went bad. This week you thermal fuse went out. This is how it happened.
You dryer cycles on a thermostat. When it goes out the dryer then cycles on the (high limit) thermal fuse. When it goes out. The dryer stops heating. You will find both after you remove the back of the dryer. They are easy to replace. There are two different thermal fuses but if you order the parts using the model number you will have no problem. These two parts are sold in a kit.
Please rate this solution.
Sep 01, 2009 | Kenmore Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
Clothes will not dry
Make sure the vent hose is clear of any clogs, then check to see if the element is coming on by pushing in the door switch with your finger and looking to the back of the inside of the dryer. You will also have to check the thermal fuse for continuity.
Jul 05, 2009 | Hotpoint NBXR333EGWW Dryer
My dryer used to shut off before the clothes are dry - now it wont start at all
Ok, the light will not come on if the door pressure swicth is damaged and, the dryer will not start if this switch is damaged as well. replace the door pressure switch asap.
Ok, concerning the interuppted drying cycle due to high heat, this can be cuased by two issue. It coudl be a venalation issue. if the dryers vent duct and exuast hoses are clogged, thsi will cuased the element to reach unsafe tempreturs, in return, tripping the high limit thermostsat and shutting the dryer off in the middle of the load cycle.
Another problme spot woul dbe a fualty high limit thermaostae. Although this is highly unlikey, this coudl be your issue.
Jun 02, 2009 | GE DBSR453EBWW Electric Dryer
It wont dry my clothes
Check the following for a gas dryer--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Check the following for a electric dryer--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jun 01, 2009 | Kenmore Dryers
Our dryer was working yesterday morning, but later in the day it would continue to run but would not produce any heat to dry the clothes.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 03, 2009 | Whirlpool ET8CHEXSQ Dryer
Kenmore cloths dryer will not heat up
3. Igniter
Oct 18, 2008 | Kenmore 659 Electric Dryer
Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Sep 15, 2008 | Frigidaire AEQ7000ES Dryer
Dryers Logo
173 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
