Question about Car Audio & Video
Jensen mcd 5060 shows am1200 on screen. will not do anything else.
  • 2 more comments
  • Wayne Misner Aug 22, 2010
    I have reset the unit. It still stays locked up.
    Wayne
    resetting the unit did not help the problem.It still shows am12oo. What is the next thing to try?
    Wayne
  • Wayne Misner Aug 23, 2010
    Thanks for all the info. It still doesnt change anything. I shut power off/unplugged wires etc. It didnt make any diff. I think I'llsend back to Jensen and see if they can fix it, Or send another one.Thanks for you effort. If you think of anything else let me Know.
    Wayne
  • Wayne Misner Aug 24, 2010
    Yes the info was helpful. It just didnt fix the problem. I have bid on one on ebay.
    Thanks again
    Wayne
  • 4,472 Answers
If the unit is under warranty definitely send it back and have jensen repair/replace the unit. If/when you find someone's information helpful please take a moment to accept/rate it accordingly.
Thank you,
Lee
Posted on Aug 23, 2010
  • 4,924 Answers
It seams that ti is stuck on a 1200 AM frequency for some reason ...try to disconnect it from the power supply ..and leave it for a while ..and connect it back ..and see how it is behaving ...If it has a security code..make sure you know it ..cause otherwise..(for ex you never disconnected it ..and it had a previous owner) it may have a code for security you are not aware about ..and you will have other problems ..
If there is no pin code..and you are sure about ..take it out from the power ..leave it a while and connect it back ...this should reset it to factory setting s..and if there is no physical damages it should get back ..
if it doesn't ..than you should take it to a repair shop cause it has something fried inside...and need to be measured part by part to figure it out..
    Genius:
  • 1,478 Answers
I will suggest you try reset the unit, once the unit is reset, the problem should be fix.
Take care.
Posted on Aug 22, 2010
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Help??
go to the repair store near your block
May 01, 2013 | Audio Players & Recorders
Jensen 9314 lcd repair. Can this be done. the screen got damaged the outer screen is ok but it looks like it shattered internally, a very small part of the screen shows
It can probably be repaired, but you will more than likely have to send it to Audiovox to get it repaired. Audiovox owns Jensen. You can get a hold of them at audiovox.com.
Aug 15, 2011 | Jensen VM9314 Car Video Player
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
Jul 29, 2011 | Car Audio & Video
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Nov 29, 2008 | Jensen MSR4050G CD Player
I have a model Jensen MCD 5110 and the face plate keeps flashing and all the stations look like they are searching for a channel..The other problem is the volume won't go past number 12 out of 46 and I can...
the unit is shot there is no hope for it. i have seen this problem many times in boats and never been able to fix the problem. i have had customers send the unit back to jensen and received a new one but check and see if your 1 yr guarantee is still good.
Aug 07, 2008 | Jensen Car Audio & Video
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
