Question about Bosch Water Heaters
Our tankless water heater is about 3 yrs old and when you take a shower the water is so hot it will burn you and when you try to cut more cold on it turns all the way cold we have it turned down as low as it will go.. I hate this water heater.. we have tried different things to fix this problem like cuttint the temp up down cuttin the hot water all the way on in the shower and turning cold water on a little at the time then it turns all the way cold then you have to cut it off and wait until it resets and start over while you are standing there with soap everywhere on ur body..any ideas are welcomed to fix this pain in my **** problem
    Scholar:
  • 122 Answers
Almost all tankless water heaters have this problem. I would install a small "buffer" tank. for example a small 5 or 10 gallon electric water heater will "mix" the water so that it doesn't come out of your shower cold, or scalding hot.
the instructions that came with your water heater should have a diagram of how to do this. if not let me know, I can send a copy.
the electric water heater acts as a mixing station.
the problem with most tankless heaters is that the water coming in is cold, average 60* and the water coming out is average 120*. sometimes the flame in the unit can't keep up when using large amounts of water, and you will get cold spots. when this happens, the heater will sense this, and then tells the flame it needs more BTU's, so then you will get extremely hot water.
the buffer tank will fix this by mixing the water before it gets to your shower and will give you an even water temperature.
let me know if this helps
Posted on Aug 23, 2010
I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem with...
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 06, 2012 | Rheem Richmond
I have a Paloma Whole Home 7.4 GPM Water Heater, it is a propane heater. I bought this heater in 07 and I get the same problem ever year. When the weather gets cold and the water is cold the hot water...
If incoming water is too cold, tankless might not have enough time to heat the water as it flows by insince the heat exchanger.
1) You can passively preheat cold water using staging tank, or tampering tank.
http://waterheatertimer.org/Tempering-tank.html
2) Buy old water heater from plumber that is not rusted out.
Replace anode rod to stop further rust.
Rinse tank with water and hydrogen peroxide to kill bacteria that results from anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
Clean sediment out of bottom:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
3) Don't forget, a tankless heater needs to be de-limed each year, and cannot be exposed to more than 11 grains hard water.
4) Since all costs are energy, when you get tired of messing with tankless.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Bosch water heater
I'd initially check for a cross connection (cold water leaking into hot water system). This can be done by shutting off the cold water feed to the tankless unit, then opening up hot water fixtures around the home. You should see the water come to a complete stop; if you see a steady stream of water, then you have a cross connection. The most common place for a cross connection is at single handled showers. The valve cartridge starts to fail over time.
Jul 09, 2009 | Bosch & Tankless LP Hot Water Heater
Hot water problem
Someone has not sized the system correctly. The water heater will heat a certain GPM a certain temperature rise. Most of those "generalizations" from the manufacturers are referencing the lowest of all the flow requirements like 2 lavatories. The truth is, don't use other fixtures while showering or get a bigger system. Lots of information related to sizing the tankless system at http://www.mechanicalengineeronline.com/Mini_Sites/Tankless_Water_Heaters_Ebook/Tankless_Water_Heaters.htm Have a good one. PS:Properly sized On-Demand water heaters are actually really good. Be prepared for the day your water heater quits.
Mar 11, 2009 | Bosch & Tankless LP Hot Water Heater
Hot and cold water from tankless heater
check your tigh/low water temperture setting. you may have them crossed.
check all of your wiring.
Jan 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
215 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
