Question about Garden
4 1/2 HP B&S motor on lawn mower. Starts and runs fine for a minute or so. Then it begins to "hunt" ie: to surge and drop off and surge and drop off, blowing black smoke as it does this. The air vane governor is either the cause or it is being affected by the problem as it moves with the change in rpm. I've cleaned the carb. Gas is fresh. I bought the mower in this condition so I don't know how long it's been like this.
  • 755 Answers
You should check the vacu jet carb on this mower for either a vacuum leak where it mounts to the gas tank, a blocked or split intake tube in the the gas tank or a weak/worn out diaphragm.
You can spray a little carb cleaner at the base of the carb while its hunting and see if it smooths out. If it does you have a warp between the carb and tank. Either the tank is bowed or the carb *(nowadays made of plastic) is not flat anymore.
You can either buy a new carb or gently sand the warped one a little and see if that works.
Be sure to take pictures of your carb setup before removing it so you can reassemble later.
Posted on Aug 23, 2010
Testimonial: "I will try these solutions. I hadn't thought of a vacuum leak or worn out diaphragm because the mower's not very old. Thanks much."
13 hp tecumseh riding mower engine surges when mower is not engaged. It runs well when mower is engaged
"Govenor hunting" caused by a lean condition ,carb is starving for fuel ! Dirt in carb or water,or out of adjustment ,or leaking throttle shaft ....usually it is a plugged low idle passage,that causes this condition,and is almost impossible to remedy,but a good cleaning might help .....does it only governor hunt at low idle ? If so thats the issue !
Jun 05, 2014 | Tecumseh Garden
Qualcast Motor Mower Starts but will not run
there will be a butter fly in the carb that pulsates this is conected to rev cable plastic may have snapped or cable come loose
take it it is petrol
Jul 29, 2012 | Garden
Briggs & stratton - after warm up engine idles rough or hunts -runs fine when cold
make sure the intake is not cracked or leaking spray carb cleaner arround gasket and carb sounds like you have a hot condition vacume leak
Jul 14, 2012 | Garden
Surging problem on 10 HP Briggs & Stratton rear mounted engine on @86 Snapper mower
Dirty fuel in the tank, breather in the filler cap blocked, or partly blocked main jet in the carb, if there is a fuel solinoid on the base of the carb check its function by removing, when the ignition is turned on the plunger should retract into its housing,
May 28, 2012 | Briggs & Stratton Briggs Stratton...
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Briggs&Stratton 4.5hp seeking/hunting
Did you replace the pump diaphragm and gasket between the carb and fuel tank? There is also a screen on the carb and a secondary pickup 'hole' on the fuel tank that needs to be cleaned between them too. You'll see that when you take the carb off the tank.
May 17, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
314 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
