Question about Craftsman 25cc Gas Line Trimmer
Bought both new gas hoses for 10 year 32cc 16inch gas trimmer. model 358799240. please help to install. THANKS
  • jcc344 Aug 22, 2010
    There are two hook ups on the primer button. Starting from the primer hooks where do we go with the gas hoses to finish.
  • 755 Answers
You need to remove the air cleaner cover first.
Then take out the air filter.
Now look at the area behind the air filter base and you will see the two fuel lines at the carb. One on the top the other on the bottom.
Remove the fuel from the trimmer by pouring it back into your gas can.
Now you can remove one of the fuel lines from the carb. Lets start with the top line. Its for fuel return to the tank.
Using a pair of angled needle nose plyers or similar tool you can grip the fuel line and give it a turn and then pull it off the carb.
Now you can reach under the fuel tank and locate the other end of this line and pull it out of the tank. There might be a round plastic washer holding the line in but most of the time its just a snug fit through the hole in the tank.
With this line removed match it to the right size line you just bought. *( many setups use different size fuel lines)
Now you need to cut one end of the new line into a V. This allows you to easily push the line through the hole in the tank.
The trick now is to have a tool that will allow you to grab the fuel line from within the tank and draw it in a few inches. Long straight needle nose or medical hemostats work well for this.
Once you have the line into the tank you can run the line back to the carb and attach. No notching needed for the carb attachments.
Now, the only difference for the other fuel line is that there is a fuel clunk *( a weighted filter) attached to the line inside the tank. You should buy a new clunk now since they tend to plug up with age. And you are doing all this line work anyways right?
Now. remove the line from the bottom of the carb and work your way back to the tank. This time you will just pull the whole line out from within the tank. This is to remove the old clunk.
With the old line out take the new line and V cut it so you can snake it into the tank. Now instead of only going in a few inches you want to pull the line up through the filler opening of the tank and cut the V notch off. Put the new clunk on. And pull the fuel line from under the tank until the clunk and about three inches of line are in the tank.
Reattached the bottom fuel line to the carb and reinstall the air filter and air cleaner cover.
Put in about half a tank of gas and check for leaks/dripping.
If she is leak free. Prime it up and start it!
Good luck and be careful!
Posted on Aug 22, 2010
  • john andrew manchook Aug 22, 2010
    The primer is hooked up inline with the return (top of carb) line. So when you replace the top fuel line. The line goes to the primer first and then on to the gas tank. This is the line that doesnt have the clunk.
    You will know if you the plumbing is right when you prime and fuel goes through the primer and you can see bubbles (or fuel once primed) coming from the unclunked line in the tank.
    You might notice if you bought one size fuel line that there are different size hose connections on the primer and carb. If you dont have a good fit be sure to go back and get more fuel line to ensure no leaks. If you have any of the old fuel line left take it with you and match it.
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
I had purchased the Craftsman 32cc grass trimmer.Model # C944.515570.I took it apart to discovery that all the fuel lines had disintegrated.Clear lines were mush.I don't want to put the same type of line...
The fuel lines you're getting in the kit are the proper ones. The only problem these fuel lines have is dealing with gas that has ethanol in it. The ethanol degrades the fuel lines, primer bulb and some seals in the carburator making them very soft (mush) and eventually fall apart. Most outdoor power equipment fuel systems are not made to deal with fuel with ethanol additives. Sorry but if you can't find gas without ethanol added in your area, you'll have to keep some extre fuel line around.
Jan 05, 2011 | Craftsman Convertible 25cc. Gas Line...
How do you replace gas filter & hose in 32cc trimmer
slice end of hose and squeeze it threw the top of tank when you can reach the hose from the fill use some needle nose and pull enough of it out of the fill spout put on filter ,place in tank and the excess pull back out of tank
Aug 18, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
71 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
