Question about Philips 50PFP5332D 50 in. Plasma Television
Half the screen is black with red dots - Philips 50PFP5332D 50 in. Plasma Television
  • Philips Master
  • 5,138 Answers
Tou either have Bad display Panel or bad capacitors they will be vented or puffed up on Top.1000uf 16v 220uf 10v 330uf 10v
Goofle to this website and type in your model number Encompass Parts Distrbution
Posted on Aug 23, 2010
3 year old Panasonic VIERA TC-P54VT25 screen has a series of horizontal red dots from left edge to middle of screen in lower half of screen. Visible when the picture is dark. Not so visible when the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2014 | Panasonic Televison & Video
The screen went black with a red streak up the middle
Hi,what makes the phone to display phone half of it is white with this big black dot to the side or red streak up the middle, is because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Jun 30, 2010 | LG Vu CU920 Cellular Phone
On the screen of my phone half of it is white with this big black dot to the side of it and i dont know what i should do?
Hi,what makes the phone to display phone half of it is white with this big black dot to the side of it,is because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Jun 23, 2010 | Motorola Mobility Rival A455 Cell Phone
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Red dots on screen
just video only what cable uusing how syour dvd player older ?
Oct 06, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Mar 29, 2008 | Car Audio & Video
Problem with wacthind dvd in full screen and black dot on screen
Not sure I understand the half of the tv and half of the dvd player. Are you saying about mid way of your set is cut off and like the bottom half you have a picture and the top no picture? I can explain the dot, first you can open back of set and maybe take off hole back bezel. Get where you can put your head down in front of C R T's (tubes) and look down in them and see if you see the same thing in one or all three of the tubes. If so this explain the dot. The half problem sounds like vertical is missing. Not sure yet! Need feed back
Aug 10, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
