Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
My Kenmore Progressive Canister turns on but there is no suction
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on Aug 22, 2010
No suction. Changed the bag and dust is all over the top of the head and the bag is totally empty. Suction dial is turned all the way up.
Likely you have a plug in the most somewhere. If you have a plumbing snake, run it through the hose to dislodge the clog or you can try blowing through the hose to confirm it is plugged.
Jun 29, 2015 | Kenmore 25512/ 25513 Progressive Canister...
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
My miele vacuum cleaner hose has no suction
have you tried changing your filters.? Also using genuine filters gives you much better suction
Feb 14, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
My Kenmore Progressive is making a noise that sounds as if something is blocking the suction. I have checked the tubes and can't find any obvious blockages
Have you changed out the bag? Checked the air filters? When you run it and hold your hand over the hose opening, do you feel suction?
Check the head for blockages, you said the tubes are good, so check the hose, if no obstructions there, open the canister and check the bag, if it's full change it, if not, pull it out and check the filter that's under the bag, if it's not clogged re-run the above steps but this time look for possible vacuum leaks. Let me know if this helps.
Oct 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
249 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
