Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
My Refrigerator side of the side-by-side isn't getting cold enough. I have it set at the coldest setting. I cleaned the air filter but still no luck. Any advise?
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 22, 2010
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
The freezer is working fine and I hear the fan in the freezer working when I open the door, however the refrigerator is not getting enough cold air into it. I place my hand under the vent where the air is...
The "control" on the freezer section is simply a mechanical air valve and controls how much freezer air actually goes into the refrigerator section. No electronics here at all.
So, IF not enough air is coming into the refrigerator, LOWER the setting on the Freezer Control .... mine has letters A B C D E try "B" and see what happens. You should feel an increased air flow at the air vent.
You may have to INCREASE the "Fresh Food Control" control to a HIGHER setting to compinsate for directing more air out out the freezer ... try 6, 7, or 8. This IS an electronic control and controls the ENTIRE refigerator's cold generation.
If this don't work, there is some other problem, like the defrost heater is out and there is lots of ice behind the back freezer wall stopping or reducing the air flow.
Aug 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side refrigerator temp is not consistently cold enough and the ice in the ice cube make melts together every few days. The temp control is turned to the coldest setting. Refrigerator is...
try runnin the vac under the fridge i know we even took the air compressor to ours to make sure all the coils were clean, worked wonders.good luck
Dec 30, 2009 | Refrigerators
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
